Need help with Envy 15t-j100
Discussion in 'HP' started by Bird333, Oct 26, 2017.
  1. Bird333
    Bird333 Notebook Guru
    I just bought this laptop and it has Win 8.1. I want to reformat (and add a partition) the drive and install Win 10 clean. Is there a guide for this laptop? I couldn't find one. Are there any special drivers I need to download before I get started? Any special precautions I need to take? TIA
  2. Danishblunt
    Danishblunt Notebook Virtuoso
    Windows 10 usually has all the drivers you need to get internet and stuff going while it downloads the rest from the internet. I would however recommend downloading new Graphicsdrivers once you installed windows 10.
    To get windows 10 on the notebook:
    - Download windows 10 iso
    - Download rufus
    - Create a bootable USB drive (at least 8GB drive) with rufus and the windows 10 image file, GPT UEFI.
    - Put USB drive into your notebook and install it like every other windows 10 version.
    - Let windows install itself, make partitions if you need etc. the whole thing is rather easy, just follow instructions from the installer etc.
    - Once windows 10 is installed and booted up, let the notebook stay turned on for around 1 hour, it will automaticly download drivers in the background and install them
    - upgrade graphicsdrivers
    - Enjoy your reformated system.
  3. Bird333
    Thanks for the reply (and including the settings for Rufus). That's basically what I was going to do. I just remembered from years ago with the HDX that there were certain files/drivers I needed from HP. As far as the graphics go, are you suggesting I download the drivers from HP or find them from Intel and Nvidia? Also, something weird wireless N is not working. The option is not in the driver options. I'm hoping its just a driver issue. I went to Realtek and I couldn't find where to download a new driver. Are there instructions for replacing the wireless card with an AC card?
