Need help with 970M Modded INF 431.60 for Windows 7
Discussion in 'Alienware M15x' started by John Nguyen, Jul 27, 2019.
  1. John Nguyen
    John Nguyen Newbie
    So I've been messing around with the .inf file and I can't seem to get the graphics driver to go through completely. I'm able to get past the System check but it fails during the install. Any help would be greatly appreciated.
  2. John Nguyen
    John Nguyen Newbie
    Nevermind I figured it out. Thanks anyway; Here's the file if anyone else needs it. This is for Windows 7 431.60. Just copy and paste into Display.Driver after extracting the Driver contents downloaded straight from Nvidia.
    https://drive.google.com/file/d/1MGWU-U6tB6txlfakS7CMmTi_YLGLWT7i/view?usp=sharing
    Or here are the lines to copy and paste yourself for future updates. Cheers.
    DEVICE ID FOR ALIENWARE
    Paste under [Manufacturer]
    %NVIDIA_DEV.13D8.02A2.1028% = Section011, PCI\VEN_10DE&DEV_13D8&SUBSYS_02A21028
    Paste under [STRINGS]
    NVIDIA_DEV.13D8.02A2.1028 = "NVIDIA GeForce GTX 970M"
    deadsmiley likes this.
