Need HELP upgrading my Serie 9
Discussion in 'Samsung' started by Kha0s, Nov 14, 2018.
  1. Kha0s
    Kha0s Newbie
    I know that this laptop is considered as old but i need help from someone that has experience with this model.
    I want to upgrade the RAM and the SSD.
    SSD- I have limited options here but from what i have seen my too choises were:
    Kingston 480G UV500 msata and the Samsung SSD 850 EVO msata
    https://www.worten.pt/informatica/armazenamento-de-dado...
    If those are not valid options can someone help find a model that fits.
    _______________________________________________________________________________
    RAM: i know thtat i can upgrade to 16Gb nut i dont know the type;i need help here too.
    Running the 'dmidecode -t memory' command i get this output:
    Getting SMBIOS data from sysfs.
    SMBIOS 2.7 present.
    Handle 0x0036, DMI type 16, 23 bytes
    Physical Memory Array
    Use: System Memory
    Error Correction Type: None
    Maximum Capacity: 32 GB
    Error Information Handle: Not Provided
    Number Of Devices: 4
    Handle 0x0037, DMI type 17, 34 bytes
    Memory Device
    Array Handle: 0x0036
    Total Width: 64 bits
    Data Width: 64 bits
    Form Factor: SODIMM
    Set: None
    Locator: ChannelA-DIMM0
    Bank Locator: BANK 0
    Type: DDR3
    Type Detail: Synchronous
    Speed: 1600 MT/s
    Manufacturer: Samsung
    Serial Number: 979F529F
    Asset Tag: 9876543210
    Part Number: M471B5273EB0-CK0
    Rank: Unknown
    Configured Memory Speed: 1600 MT/s
    Handle 0x0038, DMI type 17, 34 bytes
    Memory Device
    Total Width: Unknown
    Data Width: Unknown
    Size: No Module Installed
    Form Factor: DIMM
    Set: None
    Locator: ChannelA-DIMM1
    Bank Locator: BANK 1
    Type: Unknown
    Type Detail: None
    Speed: Unknown
    Manufacturer: Not Specified
    Serial Number: Not Specified
    Part Number: Not Specified
    Rank: Unknown
    Configured Memory Speed: Unknown
    Handle 0x0039, DMI type 17, 34 bytes
    Memory Device
    Data Width: 64 bits
    Form Factor: SODIMM
    Set: None
    Locator: ChannelB-DIMM0
    Bank Locator: BANK 2
    Type: DDR3
    Speed: 1600 MT/s
    Serial Number: 979F52EB
    Rank: Unknown
    Handle 0x003A, DMI type 17, 34 bytes
    Memory Device
    Data Width: Unknown
    Form Factor: DIMM
    Set: None
    Locator: ChannelB-DIMM1
    Bank Locator: BANK 3
    Type: Unknown
    Type Detail: None
    Speed: Unknown
    Rank: Unknown
    That means i can upgrade to 32Gb?
    My Notebook model is Samsung Serie 9 NP900X4C-A04PT.
    Thanks in advance.
  2. John Ratsey
    Upgrading the SSD to a higher capacity mSATA SSD is no problem - I had a 1TB SSD in my X4C. However, there are only two RAM slots. The main (and lengthy) discussion about the X4C is here. Upgrading to 16GB is possible but the X4C is very fussy about which RAM modules. One type which were successfully used are mentioned here.
    John
    t456 and Dannemand like this.
  3. Kha0s
    Kha0s Newbie
    My doubt was in the phisical dimensions of the ssd and the space on the notebook, were every millimeter counts.
    Regarding the RAM my model has 8Gb and for now is more than enough but i really like this computer and i was thinking in further upgrades
    Thank you for the reply. I will search in the forum for compatible modules for my Serie 9
  4. John Ratsey
    I used a Samsung 840 EVO mSATA which is about 3.8mm thick and any other SSD of similar or less thickness will work. The length and width of the mSATAs is standard. I can't see any reason why the Kingston UV500 would not work and the price is very attractive.
    John
    Kha0s likes this.
  5. Kha0s
    Kha0s Newbie
    I just needed green light from someone that had experience with one.
    If i may one more question; i know that the kingston is at very good price, but everyone that i know and in all the reviews everybody "see" the Samsung Evo as great drive. Given the prices what would be your choise?
  6. John Ratsey
    I've looked at some reviews and, while the Kingston may be slightly slower than some of the alternatives, it's the one I would buy because of the very attractive price.
    John
    Kha0s likes this.
  7. Kha0s
    Kha0s Newbie
    You were more helpful in 2 days than 1 week exchanging emails with Samung helpdesks. Thank you again
