Need help setting up Logitech V270 BT mouse on laptop
Discussion in 'Accessories' started by Murdoc, Aug 28, 2007.
  1. Murdoc
    Murdoc Notebook Evangelist
    Hello, I just bought my v270 today and well.. I have it turned on right now and I tried to add it to my BT devices but it doesn't show up at all... it seems like my M1330 doesn't even think such a thing existed... I looked up setpoint software from logitech v.247 and it doesn't work still.. can someone please help? Thanks.
  2. lskeys
    lskeys Notebook Consultant
    I have the same mouse, I had to download the Vista drivers and logitech software from the logitech web site. Install the software and reboot your pc. Also make sure bluetooth is enabled on your XPS M 1330
  3. Murdoc
    thank you for hte prompt reply.. can you please give the links to Vista drivers? I have the logitech setpoint drivers downloaded already.
  4. lskeys
  5. vespoli
    vespoli 402 NBR Reviewer
    Did you push the button on the bottom of the mouse during discovery?
    You need to make the mouse visible (discoverable).
  6. Murdoc
    you mean the "reset" button? Yes I have and yes I made sure it was on when I was doing the discovery.
  7. Murdoc
    lol found the problem... I turned off BT under BT devices ( in control panel) thx for the help guys =)
