Need help restoring the OS !
Discussion in 'ASUS Gaming Notebook Forum' started by Adilinar, Jul 28, 2011.
  1. Adilinar
    Adilinar Notebook Enthusiast
    Hello all, today I was formatting my asus (G53JW) and accidentally I forgot it was running on battery so I went to take a shower and came back, and the battery had run out, I guess you all know what happens then.
    So I tried to restore the OS by using the DVDs I created from the recovery tool, finally all the 5 cds were placed and it said the image was restored succesfully, then the computer restarts. When its booting it says the "Windows is loading files" bar, then it fills up really quick and it goes to "Starting Windows". After that, a grey wallpaper shows up, then a command prompt and then dissapears and this is where it gets stuck. It just stays on that grey wallpaper all day. I can move the mouse, but theres nothing to do with it.
    I tried booting in safe mode but it just shows a black screen with "Safe mode" on the corners.
    Please help me, its starting to frustrate me that I cant find out how to do it. I would gladly appreciate all your help!
    Thanks!!!
  2. JOSEA
    JOSEA NONE
    When you formatted if you only formatted the C partition you should still have the recovery partiton. Try starting the computer and hitting F9 after post (B4 windows loads) and restore this way.
    OR IF you have a win 7 DVD try this What are the system recovery options in Windows 7?
    To get a win 7 DVD G73 Series Driver and Application Reference
    (Win 7 Univer... )
    Once you are up and running create an image to an external hard drive with Control Panel\All Control Panel Items\Backup and Restore
    create system image, then you will never need the 5 DVD's or the ASUS recovery program.
  3. Adilinar
    Thanks for your reply. I was formatting the entire HD with two partitions, then the process got interrupted by running out of battery. Pressing F9 just takes me nowhere and back to that grey wallpaper.
    I guess Ill have to download that dvd on another computer then. Thanks!!
  4. Ulags
    Ulags Notebook Consultant
    Am struck in the same problem... Please there should be some way.. Please help..
  5. Adilinar
    Guess Im not the only one. Someone must have gone trough this and figured out.
  6. Chastity
    So you are all stalling on the recovery when using the CD Recovery? I would do as JOSEA suggested and use the F9 Recovery. I use the single partition myself since I have 2 HDD's.
    Adliner: You can boot from the Windows Install CD, and use the installer to delete the old partitions and start over. DO NOT DELETE THE RECOVERY PARTITION. (The 19.5GB one) :)
  7. Adilinar
    The F9 thing only worked when I was first restoring the hdd before it got interrupted...
    By using the windows install cd do you mean the one from the webpage mentioned above?? Because asus dont come with windows install cd ??
  8. JOSEA
    JOSEA NONE
    Dude that is correct, you will have to download and burn the DVD. AFAIK Asus stopped shipping Win 7 DVD a while ago. Mine did have one as well as a driver disk (but that was 15 months ago)
    If you do not trust my advice , trust Chastity, she has fogotten more about computers than I will ever know.
  9. Chastity
    As JOSEA said, you can download and burn the provided ISO on my driver page, or download Home Premium from the available links on a good Google search.
  10. zafota
    zafota Notebook Geek
    Chast, may i ask what would be the consequences of deleting that 19.5gb partition?
