Need Help Regarding ALIENWARE 17 R1
Discussion in 'Alienware 17 and M17x' started by ll_r1d0_ll, Sep 27, 2019.
  1. ll_r1d0_ll
    ll_r1d0_ll Notebook Evangelist
    its very hard to find LVDS cable that comes with this laptop specially in my country .. so i had no other choice rather than just plugging the lcd of m17x r4 in my laptop
  2. TheReciever
    TheReciever D! For Dragon!
    The GPU's you can use are largely the same in both laptops. The LCDs and the cables to connect them is an unknown variable.
    ll_r1d0_ll likes this.
  3. ll_r1d0_ll
    now im totally blank on what to do .. will take it to the local repair shop and see what he says and will update here (might be an MXM PORT ISSUE)....thanks for ur time :)
  4. Johndill
    Johndill Notebook Consultant
    If you disconnect the display cable from the motherboard you can then boot the system with a HDMI monitor connected. (This is something you could try if you suspect a bad display)
  5. ll_r1d0_ll
    tried this method long time ago before this issue but no luck ...well the seller has diagnosed some IC's failure issues below the MXM port section and unfortunately he is not having those ICs atm.. if he cannot find within a week, i might end up buying from ALIEXPRESS
