NEED HELP!! P375SM - Upgrade From 8970m To GTX980M
Discussion in 'Sager and Clevo' started by andrewff2, Jul 1, 2017.
  1. andrewff2
    andrewff2 Notebook Evangelist
    Hello everyone!!
    I've changey my crossfire 8970m to a 980m, everything is butter smooth games, temperature!!
    But when i go to bios it says unknown card!!
    Is there something that i should do to make it regonize?!! will it be a problem?!?!
    Should i put a new vbios or change something in my notebook bios?? right now i'm using prema V2 and here is the card!!
    And when i'm in windows the brightness doesn't work
    Any ideas?!?!?
    Any help would be awesome!!
  2. t6nn_k
    t6nn_k Notebook Consultant
    Don't worry about bios. We all have the same "unknown card".
  3. poprostujakub
    poprostujakub Notebook Consultant
    It's normal and don't have any effect on GPU working.
  4. andrewff2
    Hmm but what about the screen brightness problem? i cannot change it!?!
  5. andrewff2
    But the brightness doesnt work on windows 10, i cannot change it!
  6. poprostujakub
    Do you have hotkey installed? Or, sometimes, FN change not working and only way is using hotkey slider.
  7. andrewff2
    Yeah the problem is that WINDOWDS dont let me change the brightness
  8. andrewff2
    Tried everything, uninstall reinstall using DDU removed generic pnp monior reinstall the hotkey but nothing is working :/ this is horrible cause i like the brightness in 75%
  9. t6nn_k
    Do you have Prema BIOS and vBIOS?
    Sent from my D5803 using Tapatalk
  10. andrewff2
    just prema bios... i`ve tried to get the vbios but the site is private now T_T
    Do you have it ?? :D
