Need help installing 11.10 drivers for m17x R3
Discussion in 'Alienware 17 and M17x' started by PyroDonkey, Sep 30, 2011.
  1. PyroDonkey
    PyroDonkey Notebook Consultant
    I've been trying to install the [AIO] AMD Catalyst 11.10 Preview (8.901.0) drivers for my m17x, but I have had no luck doing it. Is there something that I need to do to get them to work because after I install it I don't get working drivers.
    I've never tried using modded drivers before, but I would really like to try these out for BF3 beta.
  2. Skatehouse
    Skatehouse Notebook Consultant
  3. Joe85
    Joe85 Notebook Deity
    ahh no wonder i BSOD!
  4. PyroDonkey
    I know. That's the exact one I am trying to use, but I can't get the video drivers to work.
  5. The Revelator
    The Revelator Notebook Prophet
    Do a clean install of the most recent Dell drivers (you don't specify which card you have, so can't point to the applicable set) after removing all existing ATI/AMD drivers through Control Panel, then Device Manager (if required), followed by Driver Sweeper in Safe Mode and registry cleanup with CCleaner or equivalent. Then install the mobility modded Cat 11.10 Preview drivers in the normal way, except choose Custom Install, and select all drivers and apps except Catalyst Control Center. This will give you all 11.10 drivers but will leave the default Dell CCC in place to permit switchable graphics. All you lose by foregoing the 11.10 version of CCC is prettier internal graphics and some slightly revised menus; there are no functional differences. Ordinarily, this approach will avoid the BSOD's, unsigned/unapproved driver issues and other problems.
  6. TostitoBandito
    TostitoBandito Notebook Evangelist
    I've installed the mobility drivers with all options (including CCC) for both 11.8 and 11.9 and switchable graphics still work for me.
    My CCC version displays as 2011.0908.1355.23115 and my driver is 8.892.0.0.
  7. The Revelator
    I've done that too, but it doesn't work for everyone, particularly with unsigned beta drivers. This is one workaround for people for whom the basic "install over" process doesn't work or that just want the new 11.10 drivers for the Battlefield 3 beta release with a minimum of driver installation hassle. If installation of the entire 11.10 Preview package works for you, then that's the way to go.
  8. Vahal
    Vahal Notebook Enthusiast
    That's what i used to do on my m17XR3 (6970m) until 11.10 preview was released. Now after the clean install of the most recent Dell drivers, i get a BSOD when i install 11.10 preview over them, with or without checking CCC.
    After this BSOD, i can see in my CCC that the 11.10 are installed, but the installation process didn't success ...
    So if i want a "clean" install, i'm stuck with the 11.9, and i can't fully enjoy BF3.
  9. TostitoBandito
    Ah, ok.
    I have a pretty strict policy of not ever using any "beta" or RC drivers, so I never experienced that issue. The 11.8 and 11.9 versions I have used were the official certified versions.
    As for 11.10 and BF3, I'm assuming they will be released officially prior to the game being released.
    That said, 11.9 is a little faster across the board for me than 11.8. I do just fine in the BF3 beta with nearly everything on ultra with a moderate GPU overclock.
  10. The Revelator
    Not sure I understand this. If you can see that 11.10 drivers are installed in CCC, then they ought to be installed. Which version of CCC are you looking at? Which driver is shown for the 6970M in Device Manager? Which driver is shown in GPU-Z? Don't let a little BSOD throw you off.
