Need Help from a CF-29 expert
Discussion in 'Panasonic' started by VSchneider, Jun 4, 2012.
  1. VSchneider
    VSchneider Newbie
    I recently bought a used CF-29 MK5 and when I got it it is missing the cover plate that is right above the battery cover. Is it just a cover plate or is there something supposed to be in there?
    Any help would be great.
    Thanks
    Van
  2. Rob
    Rob Toughbook Aficionado
    That is the WWAN blank cover. The P/N info is below so you can order it from Heartland Services (913)-685-8855
    DFGE0077ZA-0 WM COVER
  3. techtuff
    techtuff Notebook Geek
    Send me a pic of your exposed area to make sure its the cover I think it is... Just dismembered a few salvage units I am pretty I have one, I will mail it for free.
    Peace
  4. Rob
    He can't PM... Just post it here on this thread.
  5. SHEEPMAN!
    SHEEPMAN! Freelance
    If the unit is missing that piece...take a glance inside with battery in. If you see a connector above the battery (facing toward you)...and the unit has a wwan antenna in the lid corner.....the missing piece is a sled.
    Put a blank cover from techtuff in there and don't worry about it.
    Your complete model number would "tell the tale".
  6. VSchneider
    VSchneider Newbie
    Thanks for the help guys. I will snap a picture tomorrow and post it. To answer your questions Sadlmkr, yes there is a connector above the battery facing out and it has the antenna in the corner. The complete model # is CF-29NTQGTBM. Is that where the wireless network card should be?
    Thanks again,
    Van
  7. SHEEPMAN!
    SHEEPMAN! Freelance
    Yup. Western term. :)
    N=Mk5 PentiumM 778 802.11a,b,g TPM
    T=Touch
    Q=80GB drive- 512 Ram
    G=Floppy- Ethernet
    T= " " " Edge(Cingular)
    B=XPP COA I think.
    M=North America
    If you used a WWAN, what carrier would it be?
    Any sled including my GPS mod would fit.
    Sorry for the top of the head bit here...I'm cooking dinner.
    Does the touchscreen work?
    Jeff glad to help and welcome
    TEST site:forum.notebookreview.com/panasonic - Google Search
    Replace TEST with your search in this forum. :D
  8. db04p71
    db04p71 Notebook Deity
    Model Number: CF-29NTQGTBM Status: DISCONTINUED MSRP: $4,872
    Description: Intel Pentium M 778 1.6GHzLv (Centrino),13.3" Touch XGA,512MB,80GB,Intel 802.11a+b+g, WIN XP SP2, CINGULAR EDGE EDGE, TPM1.2, no drive
    No, that is where the Cingular Edge sled mounts. IOW, WWAN.
    The wireless network card, Intel 802.11a+b+g, is accessed by removing the bottom of the case.
  9. SHEEPMAN!
    SHEEPMAN! Freelance
    Thanks Glen,....he said wireless and I heard WWAN.
    Preciate it.
    Jeff
  10. TopCop1988
    TopCop1988 Toughbook Aficionado
    Model Number: CF-29NTQGZBM
    MSRP: $4,295
    Description: Intel® Pentium M 778 1.6GHz LV (Centrino),13.3" XGA Touch Screen, 512MB RAM, 80GB HDD, Intel® Centrino® PRO/Wireless 2915ABG 802.11 a+b+g WLAN, Microsoft® Windows® XP Professional w/Service Pack 2, TPM 1.2 Security Chip, No Optical Drive
    THe slot recepticle above the battery chamber is where Panasonic installed a Wireless Wide Area Network (WWAN; or mobile broadband) card and/or GPS unit.
