Need help deciding on gaming laptop
Discussion in 'What Notebook Should I Buy?' started by InfectedSonic, Aug 8, 2019.
  1. InfectedSonic
    InfectedSonic Notebook Evangelist
    General Questions
    1) What is your budget?
    4000
    Desktop Replacement; 17"+ screen
    3) Which country will you buying this notebook?
    United states
    I don't discriminate
    No I want a new one
    Gaming and watching movies
    Both but portability doesn't matter
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?) All of em
    Battery life is of no consequence
    That's ok
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Windows
    Screen Specifics
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    1080p minimum
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.) Not important
    Build Quality and Design
    14) Are the notebook's looks and stylishness important to you? Not really but don't want a fugly notebook
    Notebook Components
    15) How much hard drive space do you need?
    Not important
    Timing, Warranty and Longevity
    16) When are you buying this laptop?
    Now would be nice but I don't mind waiting
    17) How long do you expect to use this laptop?
    As long as possible
    18) How long could you afford to do without your laptop if it were to fail? Not having one would suck but I'll live
    19) Would you be willing to pay significantly extra for on-site warranty, or would it be acceptable to you to have to ship the laptop to the vendor for repair with perhaps a week or more outage? As long as it comes back fixed the first time it's ok
    I had my eyes on the clevo 775 with 9700k and rtx 2080 but have been looking at the area 51m also just really concerned with overheating
  2. Felix_Argyle
    Felix_Argyle Notebook Consultant
    Alienware 51m has a high failure rate, you can find examples in these forums and on Reddit. Take a look at something like MSI GT76 instead. You should never have overheating issues with that - it has huge air intake on bottom and plenty of exhausts on back and sides and MSI goes as far as polishing the heatsink surface for better heat conductivity (smooth metal surface always transfer heat better than the one with scratches).
  3. InfectedSonic
    I want something that's upgradeable for future gpus. I also do not want a maxq gpu. I'm not sure if either of those things apply to the msi that you mentioned I still need to look it up. As for the Alienware failure rate it's my understanding that it was due to the gpu and it has been rectified or am I mistaken?
  4. Felix_Argyle
    Alienware does have a removable video card but you may never see any upgrades for it in future. And I am not sure they fixed the issue which was causing some components to burn up - they never officially confirmed this. In any case, I would recommend an extended warranty for it if you will be buying it and I would avoid buying it from any third-party reseller because it caused some issues for some people (Dell was telling some people that some resellers are not authorized to sell).
  5. InfectedSonic
    I looked for a long time at my options and I decided to order the Alienware area 51m. For the best possibility of upgrades in the future but also because I got it for 798 off with their sale along with a coupon code I found.
