Need help converting bases with C++
Discussion in 'Off Topic' started by Mastershroom, Jun 28, 2011.
  1. Mastershroom
    Mastershroom wat
    Not well enough to pass. :p
    In the end it's pretty much irrelevant at this point; I'm changing my major away from CS. Between this class and the other CS classes I took, I learned that it's really not for me. I haven't decided what I'm changing to yet, but it's a start. :p
  2. talin
    talin Notebook Prophet
    That's a pity, but best of luck in your new major (whatever it will be :p).
  3. redrazor11
    redrazor11 Formerly waterwizard11
    Goodluck with it. I've changed my major 3+ times but finally landed on CS. Only a year left till i get my B.S.
    Even if you don't study it anymore, the fundamentals of machine logic will help you in all areas of life. Especially videogames :p
  4. Zoran Horvat
    Zoran Horvat Newbie
    You can convert number in any base into any other base using this pseudocode:
    function ConvertNumber(number, b, d)
    begin
    newNumber = ""
    while number <> "0"
    begin
    number = Divide(number, b, d, out remainder)
    newDigit = ValueToDigit(remainder)
    newNumber = Concatenate(newDigit, newNumber)
    end
    if newNumber ="" then
    newNumber = "0"
    end
    function Divide(number, base, divisor, out remainder)
    begin
    remainder = 0
    result = ""
    for i = 0 to Length(number) - 1
    begin
    digitValue = DigitToValue(number)
    remainder = base * remainder + digitValue
    newDigitValue = remainder / divisor -- integer division
    remainder = remainder mod divisor
    if newDigitValue > 0 OR result <> "" then
    newDigit = ValueToDigit(newDigitValue)
    result = Concatenate(result, newDigit)
    end
    if result = "" then
    result = "0"
    return result
    end
    MOD EDIT: Don't link to your own website.
