Need help choosing the next laptop
Discussion in 'MSI' started by nader_rizk2003, Jan 9, 2019.
  1. Support.3@XOTIC PC
    Support.3@XOTIC PC Company Representative
    IIRC the 18" models usually lag the others in terms of announcement and release. While I haven't heard anything about them I'd guess there will be an RTX version eventually. Whether they get a better panel will likely determine whether I recommend them.
  2. ryzeki
    ryzeki Super Moderator Super Moderator
    If I remember correctly, the limit of the bigger 18 machines was that there isnt a big enough market for that particular size, so there arent as good or varied panel options right? I liked MSI GT80 series and the idea, but since SLI had really dwindled including how only the RTX 2080/ti support it and not the lower end GPUs, I think the GT8X line will either die or evolve into something else.
    Imo they should make the GT8X line their full desktop monster, and single GPU. Change it so that they use socketed CPUs and the higher end single full GPU. I believe 18 inchers would only have 4K screens as option instead of high refresh, but the best would be a high refresh 1440p panel.
    custom90gt likes this.
  3. Spartan
    Spartan Notebook Nobel Laureate
    I love the GT83's size but as long as it has that 60hz crappy panel I won't touch it
    nader_rizk2003 likes this.
  4. Support.3@XOTIC PC
    That's pretty much exactly it, while they're popular and sell pretty well, I don't think they move in enough volume to incentivize really good but still affordable panels for them.
    ryzeki likes this.
  5. nader_rizk2003
    nader_rizk2003 Notebook Evangelist
    you are right. the GT83 is very good but as you said the 60hz panel is bad
  6. ryzeki
    It's not bad, its simply outdated. It was okay almost 4 years ago. At this point every competitor either has a sharper, faster or better looking panel, so its definitely a disadvantage.
    custom90gt and nader_rizk2003 like this.
  7. sidworld
    sidworld Newbie
    Panel aside, would you opt for a GT83 with a 8850H and a gtx 1080 sli when compared to a clevo p775 with a 9900k and an rtx 2080. Both are priced around $3000 right now and I was wondering what would be a better pick for somebody using it for more intensive modeling/simulations (primary use) and moderate gaming (secondary use).
    My concern with the p775 is the thermal heating of the 9900k (seems difficult enough to cool it down in a desktop, let alone on the "thinnest 17-inch desktop replacement" as sager seems to claim on their website), which might prevent the 9900k from reaching its true potential. Thoughts or suggestions would be useful as I am deciding on which one to pick for my next laptop. Thanks!
  8. Spartan
    If you get it from HIDevolution with their thermal mods like Thermal Grizzly Conductonaut + Fujipoly Extreme thermal pads then you will be fine. They are also a Prema Partner so you will get the Prema BIOS for free which is a MUST on Clevo laptops.
    Prema BIOS Benefits:
    • Restores user ability to overclock or underclock the CPU
    • Restores user control over CPU power settings (voltage, watts, amps) for optimal performance and/or thermal efficiency
    • Restores ability to control non-turbo CPU core ratio
    • Restores ability to control CPU c-states and p-states
    • Restores ability to control BCLK (northbridge) and FCLK (System Agent) frequency
    • Restores ability to enable Intel Speed Shift Technology functionality
    • Restores ability to disable Intel Software Guard Extensions (SGX) functionality which is intended for software developers who want to use that feature and causes erratic system behavior
    • Restores ability to control RSR, Watchdog Timer, ASPM, ACPI sleep and hibernation functionality
    • Restores ability to control RAM timings, clock speeds and enables the utilization of XMP profiles
    • Restores ability to control selection of Legacy, UEFI and CSM to install whatever operating system is desired
    • Restores ability to control CPU-based DEP, AES (encryption) and Virtualization
    • Restores ability to control GPU scaling, PCIe speed and power management features
    • Restores control over Thunderbolt and USB 3.1 configuration
    • Restores control over SATA port configuration and Intel LPM. Having the ability to disable drive ports allows exclusive control over what drive receives the BCD/boot sector, system and recovery partitions during Windows Setup and eliminates the need to physically remove non-OS drives when installing a new OS.
    sidworld likes this.
  9. ryzeki
    Nope, I would not go for the GT83 anymore. Sadly SLI is going to be dropped sooner rather than later, and for the same price you get a better processor and GPU than the GT83.
    Even if the thermal performance of the Clevo is not enough for the full 9900K, its still going to be faster than any mobile i7/i9 since it is a 8 core 16 thread CPU.
    You can perform actions to handle the heat in the Clevo to make it super performing, but the GT83 will be always limited in comparison. Other options against the GT83 in MSI world would be the GT75.
  10. Support.3@XOTIC PC
    In that comparison the p775 wins IMO. Upgrade the thermal compound on it and it will treat you well.
    nader_rizk2003 and sidworld like this.
