Need help choosing/finding a laptop by Dec 8 or Jan 1
Discussion in 'What Notebook Should I Buy?' started by Phillip, Dec 3, 2007.
  1. Phillip
    Phillip Phillip J. Fry
    1) What is your budget?
    ~under $900USD (the cheaper the better)
    d. Desktop Replacement; 17" screen
    3) Please select your country's flag as a post icon and tell us what country are you buying this in.
    USA
    Not gateway, or compac
    5) What tasks will you be performing with the notebook?
    Office apps, Web browsing, occasional video watching (mostly youtube but some DVD)
    6) Will you be taking the notebook with you to different places or leaving it on your desk?
    home to Office and back home again
    7) Will you be playing games on it; if so, which games?
    unlikely. Solitare or MS hearts at most
    8) How many hours of battery life do you need?
    well being a 17" laptop Im not expecting much but ~3hrs would be nice though unlikely
    9) Do you mind buying online without seeing the notebook in person?
    not at all.
    however instore would be convenient
    10) What OS do you prefer? Windows (XP or Vista), Mac OS, Linux, etc.
    XP or Vista
    Screen Specifics
    11) Would you prefer standard or widescreen?
    widescreen
    12) From the choices below, what screen resolutions would you prefer?
    doesn't matter in this case
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen?
    either
    Build Quality and Design
    needs to look(and be) relatively well built
    15) When are you buying this laptop and how long do you want this laptop to last?
    Sat Dec8 or by New years week (Jan 1-7)
    Notebook Components
    16) How much hard drive space do you want; 40GB to 200GB?
    minimum of 100GB but the more the better
    17) Do you need an optical drive? If yes, a DVD, Blu-Ray or HD-DVD drive?
    DVD-RW/CDRW combo drive
    OK now that thats out the way lets get down to the nitty grtty
    My dad wants needs a laptop for work. He doesn't want to spend much money. It would seem that he would prefer to buy from a local shop but I could convinve him to buy online if a better deal is presented.
    right now AMD seems to be the only option in his price range.
    with that being said I have some questions.
    besides running hotter and less battery life and perhaps multitask peformance if you push it to the limit, and the fact that its AMD, is there any reason not to get an AMD equipped laptop?
    If AMD is ok to get which is better Athlon or Turion? is there a huge difference? for what I/he wants(see FAQ above) is there a reason to get one over the other?
    Also, he is looking at an HP and Toshiba at Office Depot
    the specs are as follows:
    HP PAVILION DV9620 US
    17" WXGA+BrightView
    AMD Turion 64 x2 TL-58 1.9GHz 1MB L2 cache 1600MHz FSB
    2.0GB DDR2 RAM
    2X120GB SATA HDDs
    WinVista Home Premium
    LightScribe SuperMulti DVD
    802.11 b/g wireless
    4 USB2.0 1 FireWire 1 S-video
    5-in-1 reader
    Toshiba Satelite P205D-s7454
    17" WXGA+TruBrite
    AMD Turion 64 x2 TL-58 1.9GHz 1MB L2 cache 800MHz FSB
    2.0GB PC2-5300 DDR2 RAM
    160GB 5400rpm SATA HDD
    LabelFlash SuperMulti DVD
    802.11 b/g wireless
    6 USB2.0 1 FireWire 1 S-Video
    5-in-1 reader
    He's leaning towards the HP and if nothing comes up as a better deal he's probably going to get it by Sat Dec 8.
    Im basically trying to see if this is a decent laptop before he buys it so that he doesn't spend ~500-900USD on a paperweight.
    Thanks in advance, I look forward to reading your post
    Fry
  2. Lithus
    Lithus NBR Janitor
  3. Phillip
    I took a look and nothing struck my fancy.
    they were all over priced compared to what I listed in my first post
  4. jetstar
    jetstar Notebook Deity
    The Vostro 1700 is a good option.
  5. Phillip
    I was thinking about that but it's a tad expensive if you get anthing besids the absolute base model.
    He really wants to spend less than 800USD or at most 850.
    money is extremely tight right now.
    Also, what about the AMD CPUs are they a bad omin or is Intel just the prefered option?
  6. fabarati
    fabarati Frorum Obfuscator
    The AMD's are more that enough for that. I do that with a 1GHz Core 2 Duo. So you're golden.
  7. Phillip
    but what I really want to know is; is it OK to get AMD?
    everyone seems to be bashing them lately?
    I've trusted them in the past, I just want to know if it would be a mistake to trust them now.
  8. Bombers
    Bombers Notebook Geek
    Are you using the 30% coupon for the HP? That can help you bump up to the Intel.
  9. Phillip
    no, I was unaware of the coupon.
    do I have to buy through the HP site to use it?
    or could I go to OfficeDepot and use it as well?
    where is this coupon?
  10. fabarati
    The reason people are bashing AMD is that they have slower, more powerhungry and hotter chips than Intel. And they act like their stuff is as good as intels. But it's more than enough for most usages. Especially then higher clocked ones. But if the intel is about the same price, go for that.
  11. Phillip
    anybody mind pointing me in the direction of the HP coupon?
  12. Johnny T
    Johnny T Forum Moderator Super Moderator
    It not there anymore...I pointed it out in TRT last week but you didn't see :(
    Although the is a HP dv96xx with AMD CPU for $699, just scroll down the deals section :)
  13. Phillip
    I'm a bit all thumbs, Im having trouble finding it.
  14. Bombers
    Hmm. It expired today from the stickies in the HP forum even though the exp date is 12/8.
  15. Phillip
    so no more coupon then?
    in that case the instore model will be cheaper.
  16. Johnny T
  17. Phillip
    for some reason it doesn't work, or at least, it doesn't work on 17" laptops.
  18. Phillip
    Thanks to all who have helped me.
    He bought an HP dv9620, the one I posted in the first post of this thread.
    Ill post pics when I get the chance
    Thanks again
    Fry
