NEED Bluetooth Peripheral Device Driver!!!!!!!!!
Discussion in 'HP' started by BLACKMAMBA123, Jun 16, 2008.
  1. BLACKMAMBA123
    BLACKMAMBA123 Notebook Guru
    hi guys...im facing a annoying problem that after updating my windows ...nw when i connect to bluetooth device it says "Bluetooth Peripheral Device" not found....HELP ME....where i will get this driver....????
  2. PhoenixFx
    PhoenixFx Notebook Virtuoso
    What is your Bluetooth device ? A mobile phone / PDA ? If so, it might be trying to install all the services supported by it over Bluetooth (i.e Modem, and whatever other services provided by device). Use the driver CD of your BT device (if you have one).
  3. BLACKMAMBA123
    im trying to connect to a Mobile phone K770.....i dnt have a bluetooth driver cd for my system.....actually im not using the windows which came with the loptop bcoz it was too slow so i install my own vista home prium n downloaded softwares ffrom HP site........
  4. netkiller
    netkiller Notebook Consultant
  5. PhoenixFx
  6. BLACKMAMBA123
    ok i will try n let u knw.........but on my original OS it was not required???
  7. BLACKMAMBA123
    my prob is not solved by installing PCsuite .....i checked for an online solution and it said......
    so help me how to update SYNC Profile.....
