Need advice: how to open .ofx file
Discussion in 'Windows OS and Software' started by stevoboy, Jan 4, 2009.
  1. stevoboy
    stevoboy Notebook Guru
    As per title, my bank statement comes in this format and I don't know what program to use to open it. Any advice?
  2. TabbedOut
    TabbedOut Notebook Evangelist
  3. ATG
    ATG 2x4 Super Moderator
  4. entropy.cz
    entropy.cz Notebook Evangelist
  5. zakaluka
    zakaluka Notebook Consultant
    Financial software like Microsoft Money, GNUCash, etc can handle OFX files. If you use one of those (and the software doesn't already work with the files you downloaded), check out http://www.mt2ofx.tk/.
    If you want to open the files in Excel, you need some kind of converter or plugin. One can be found at http://www.bigredconsulting.com/aboutofxreader.htm.
    Regards,
    z.
  6. qhn
    qhn Notebook User
    Can you also ask the bank to send the statements to you in a different format? I requested mine in pdf, and they gladly complied.
    Many good sugestions from above posts.
    cheers ...
