Need a rugged truck...
Discussion in 'Motorized Vehicles' started by CanadianDude, Sep 16, 2010.
  1. CanadianDude
    CanadianDude Notebook Deity
    I'm looking to get an SUV of some type to compliment my Mustang. Compliment as in a daily driver/beater for when I don't need/want to drive my 5 litre Mustang.
    I'm mainly looking for reliability and ruggedness. I have, at MOST $14000 to spend, so I'm looking at used.
    Some that I've been looking at are:
    Ford Explorer, Toyota 4 runner, Nissan Xterra
    ANy others you can think of let me know.
  2. H.A.L. 9000
    H.A.L. 9000 Occam's Chainsaw
    The 4-Runner is a good choice, so is the Xterra, but the Explorer.... no, please. The Nissan is going to have the better engine with the 4.0L VQ40DE, which is a larger version of what's in the Maxima/Z/Quest (3.5L). They're smooth and reliable, and have a fair amount of torque. The 4-Runner has a 4.0L or 4.7L V-6 or V-8. The 2UZ-FE V8 is the one I'd look for, as that was basically the Lexus engine. Also, if you get one with the 2UZ-FE, chances are it was assembled by my uncle at Toyota Motor Manufacturing Plant in Huntsville, Alabama.
  3. Muscle Master
    Muscle Master Notebook Consultant
    You will want a 4x4 Jeep Grand Cherokee!!!!!
    Hands down.. try between 07-09 years.. I'm sure you will get a great price
  4. crazycanuk
    crazycanuk Notebook Virtuoso
    or a 95-99 model and have fun changing the drivetrain however you want.
  5. jooooeee
    jooooeee Stealth in disguise
  6. Modly
    Modly Warranty Voider
    If you want a really rugged SUV, get an Excursion. Get it with a diesel, and it will make it very reliable too.
    I'm not going to lie to you though, I wouldn't classify anything that has a budget of $14,000 as a beater....
    If you really want a beater, get a mid-80's K5 blazer. You can pick one up for less than $1000 easily, and it will leave you with a few grand to spend modding it a bit.
  7. Syndrome
    Syndrome Torque Matters
    Don't waste your time on a flowerjoke(ford diesel), you'll have to remove the cab once you blow your head gasket, or pull the motor. And if you ever do ANY performance mods to it(even a chip) you will blow the head gasket.
  8. CanadianDude
    Well I said at most $14K...if I find something cheaper than by all means I'd go with that.
    I'm actually looking at a couple of 1998 - 1999 4 Runners. I drove these and is it just me or do the late 90's Toyotas all seem to have higher build quality than the new ones? I also drove a few 1995-1996 Camrys and those things do not rattle or squeak at all and they feel solid.
    I did consider Jeep. I looked at a 1995 Jeep Grand Cherokee V6. LOVED that thing for the day I had it. Drove smoothly, looks cool, but the guy was asking too much for it.
    Tomorrow I am going to check out some used Ford Explorers.
    To be honest, the Subaru impreza 5-door caught my eye as well (the newest iteration). Although its over my budget, I think that would be a sweet little wagon to have.
  9. Colton
    Colton Also Proudly American
    A 4-Runner would be your best bet. They are very reliable and are a blast to drive. Stay away from Ford Explorers, they are not worth the trouble.
  10. Thaenatos
    Thaenatos Zero Cool
    Jeep. Will get you tons of use and can be beaten on a regular basis with no worries. Plus they can be had for very cheap.
