Need a Razer Blade Pro 17 2070Max-q vbios
Discussion in 'Razer' started by HandsomeGhost, Aug 27, 2019.
  1. bjrebo
    bjrebo Notebook Consultant
    Great score!
    MagillaGorilla likes this.
  2. falkio
    falkio Notebook Enthusiast
    Can you please give me your complete TS settings. I am unexperienced with TS but want to give it a try. Thanks.
  3. HandsomeGhost
    HandsomeGhost Notebook Guru
    @MagillaGorilla I see you have the mid 2019 edition. I wonder if thats why its working for you. Can you go into more detail on your settings. Did you reinstall your drivers and what power plan are you on. I have the early 2019 model and I cant pass 90watt with the modded vbios.
  4. amihail91
    amihail91 Notebook Evangelist
    Where did you find the 100w VBIOS?
  5. HandsomeGhost
    On the first page there is a mega link.
  6. eddi3x3x3
    eddi3x3x3 Notebook Evangelist
    Anyone know if it would be possible to flash the 100w 2070 on the new razerblade 15 with the 2070 max q and optical key switches? or would that require more looking into before it's confirmed? I'm considering getting a blade but a 80w 2070 max q isn't very appealing to me vs at least a 90w variant or higher. Currently have an alienware m15 r1 with 1070 max q and firestrike graphic score is around 15,000. Not sure if the 2070 max q stock will be that much of an upgrade (unless it's possible to flash the 90w or 100w vbios)
  7. rinneh
    rinneh Notebook Prophet
    The 2070MQ is touching 17500 in firestrike at stock.
    and like i mentioned in the other topic, flashing the bios to push the wattage higher is asking for trouble in such a thermal constrained machine where currently more and more cases of the 2018 model are popping up with bloated batteries. The VRM section is close to the battery together with the NVME SSD.
  8. Zuanvl
    Zuanvl Notebook Enthusiast
  9. seanwee
    seanwee Notebook Deity
    No. It will just behave like any other 90w 2080 Max-q vbios on MSI laptops.
    Correction: 2070 Max-q
  10. Zuanvl
    ok thanks:(
