Need a Razer Blade Pro 17 2070Max-q vbios
Discussion in 'Razer' started by HandsomeGhost, Aug 27, 2019.
  1. HandsomeGhost
    HandsomeGhost Notebook Guru
    Why do I have to be on bios 1.04? Im on 1.05 and cant seem to find a link for 1.04.
  2. HandsomeGhost
  3. Hackintoshihope
    Never mind if you are on higher than 1.04 then you should be okay I just knew that when I was on 1.02 it wouldn’t work...
    Also I’m referring to high performance mode in razer synapse.
  4. bjrebo
    bjrebo Notebook Consultant
    I am on bios 1.02. I tried to do the update to 1.05 and it failed at the end. Thank goodness i did a power off and computer came back up. I would not suggest anyone doing this update especially if you are on the modded pl throttle bios.
  5. Hackintoshihope
    Usually it will hang and once you restart you will indeed be on the updated bios and then you will need to do the power limit modification again. But 1.04 and up has fixes for the 100W vbios to actually allow you to use it.
  6. HandsomeGhost
    Im in bios 1.05 and im not able to pass 90watt with the RBP 2070 vbios.Max-q.
  7. Hackintoshihope
    Even when using the performance preset in synapse? If that is so I would try 1.04.
  8. bjrebo
    Can anyone confirm that they are at 100w and if so what system bios are you using?
    I am on 1.02 and only seeing 90 watts. You can look at HWINFO sensor data and it will show max wattage. You may be in the range of 89-93 but we need to see one that says 100-102
  9. MagillaGorilla
    MagillaGorilla Newbie
    So it's taken a lot of trial and error, but I finally broke 18k on Firestrike:
    https://www.3dmark.com/3dm/39870842
    Steps:
    - Flashed Vbios from RBP 2070 - 100w (stock was 80, and I had previously flashed 90w)
    - Tried the BIOS mod, but ended up reverting the changes. - Raised CPU but lowered GPU scores
    - Ended up ordering some Kryonaut and repasted.
    - Throttlestop set to -.135 cpu core & cache, and -.06 IGPU, Turbo capped @ 4.4ghz, Speedshift 0
    - Synapse set to gaming mode, fans @ 5000 (I managed to keep Synapse v3.4.414.41716 as to not lose control of my fans, in favor of "creator/custom modes" which are on newer versions...
    Really happy with my score, and my max temps were 74c
  10. MagillaGorilla
    I'm on 1.04 and getting 100w max: https://imgur.com/ETugOGx
