Need a Razer Blade Pro 17 2070Max-q vbios
Discussion in 'Razer' started by HandsomeGhost, Aug 27, 2019.
  1. Flonky
    Flonky Newbie
    Sweet! That is indeed impressive.
    I did compare to some results from notebookcheck and Jarrodstech.
    As far as I die get everything right that is almost the graphics score of a 2080 Max-Q. And some bit higher then the 2070 non Max-Q of the Asus Zephyrus.
    Did you do anything Else to your Blade?
    I also noticed that you are using Kingston RAM. Which one did you buy?
    Thanks a lot guys!
    Cheers!
    MagillaGorilla likes this.
  2. MagillaGorilla
    MagillaGorilla Newbie
    Hey! In regards to my steps:
    - My 2070 is flashed to the RBPro vbios
    - Throttlestop set to -.130
    - Afterburner set to +100 curve, and +500 memory
    I also heavily customize my Windows (1903) to run as minimally as possible.
    PS, here's the RAM:
    https://www.amazon.com/Kingston-Tec...l14+2666&qid=1569352187&s=gateway&sr=8-1&th=1
  3. bjrebo
    bjrebo Notebook Consultant
    I am going to do this today. Does anyone know if i need to use the protectoff command with this being a razer bios? I will post my results once the flash is complete.
  4. seanwee
    seanwee Notebook Deity
    Not a 2070 but I flashed my 2080 with the RB Pro 17's 100w vbios just fine without the protectoff command.
  5. bjrebo
    I did the flash and it says something like these do not match do you want to override. went from 200X to 300x version. Flash took. My scores are exactly the same as before. About 20k on firestrike and 7600 on timespy.
  6. seanwee
    To be expected
    Try uninstalling drivers with DDU and install fresh drivers.
  7. bjrebo
    i did the DDU and also tried reflashing with protectoff and it shows flashing but my results do not change. Any other thoughts?
  8. HandsomeGhost
    HandsomeGhost Notebook Guru
    With the new 2070Max-q vbios flashed the my tdp still stayed at 90watt as shown in HWiNFO.
    I also check the rom file with Mobile Pascal TDP Tweaker and I noticed the target mw is 90000 but the limit is 10000. I don't know if this has anything to do with it?
  9. bjrebo
    note that GPUZ still shows 2002 as my device id. Should that change to 3000?
  10. Hackintoshihope
    Youve got to use the main board bios 1.04 and run in high performance mode to use the 100W portion of the vbios.
  11. bjrebo
    I am on the modded bios and it shows version 1.02. Sounds like you are saying i need to flash to 1.04 and lose the Throttle controller bios to get the 100 watt GPU vbios to work.
