Need a Razer Blade Pro 17 2070Max-q vbios
Discussion in 'Razer' started by HandsomeGhost, Aug 27, 2019.
  1. Hackintoshihope
    You have to use a Razer Max q or other max q 100W vbios if you try the max p it will not clock right as you are seeing. That’s why you need the 100w from the razer blade pro.
    HandsomeGhost likes this.
  2. HandsomeGhost
    HandsomeGhost Notebook Guru
    Oh okay thanks for clarifying. Now I can stop searching online on why it wasn't working.
  3. Hackintoshihope
    We experienced this trying to flash max p vbios on our 2080 doesn’t work. Something weird with how drivers install and show a false power usage and extremely low clock rate.
    seanwee and HandsomeGhost like this.
  4. seanwee
    seanwee Notebook Deity
    I think it has something to do with the drivers still identifying that our gpus are Max-q models.
    I've looked through forums where people have successfully flashed a higher tdp bios and they always report msi afterburner showing the name of the gpu they flashed to.
  5. HandsomeGhost
    Interesting. That would make sense it does still show as the Max-q variant after. Any ideas on what we can do?
  6. seanwee
    I'm working on trying to spoof the gpu hardware ID.
  7. HandsomeGhost
    Awesome hopefully it works.
  8. seanwee
  9. HandsomeGhost
    Okay I’ll check it out. Thanks
  10. bjrebo
    bjrebo Notebook Consultant
    sorry i should clarify, i can do 1515 at .700mv and can do 1650 at .750. What i will tell you is there is almost no performance difference between the two. I actually had a timespy run that put me within one point of the razer blade 15 highest score. I think it was close to 7800 GPU score if i remember correctly. did we ever find a 100watt razer bios? I have plenty of thermal left to push. CPU is around 80 and GPU runs around 77-79 in Anthem which is the most demanding game i play.
