Need a Razer Blade Pro 17 2070Max-q vbios
Discussion in 'Razer' started by HandsomeGhost, Aug 27, 2019.
  1. Iainbn
    Iainbn Newbie
    Hey, what vbios did you go with as your Google drive no longer has it within it?
  2. nyichiban
    nyichiban Notebook Consultant
    Pretty sure he used the vbios on the first page plus some tweaks with overclock and such.
  3. Iainbn
    Iainbn Newbie
    Oh really, thought he had found a way to stop the clocks dropping when gpu over 90% utilisation
  4. nyichiban
    He tells you what he did in the first post you quoted by him. I had mine setup the same way and no issue son my end.
  5. Pplusk
    Pplusk Newbie
    Please reply if some one got. the 8750 to work ! Thanks
  6. SUADE8880
    SUADE8880 Notebook Evangelist
    This is a gutsy little card. Just got the laptop for 4 hours to quickly flash vbios and LM the cpu and gpu. No other tweaking but overclocking the gpu and undervolt cpu at -150.
  7. seanwee
    seanwee Notebook Deity
    What overclocks are you running on the card?
    I've seen 2070 Max-q cards hit 20k and brush up against 21k in some instances.
    People usually don't overclock the memory enough. Core should be around +140 to + 160mhz while memory should be +600 to +800mhz
  8. SUADE8880
    Core +170mhz
    Memory +425mhz
    I will play with it some more later but I'm pretty sure it will be hitting over 20k.
  9. seanwee
    Have you unlocked your cpu power limit yet?
  10. SUADE8880
    Not yet. I’ll be tinkering with it some more in the next few days.
