Need a Razer Blade Pro 17 2070Max-q vbios
Discussion in 'Razer' started by HandsomeGhost, Aug 27, 2019.
  1. HandsomeGhost
    HandsomeGhost Notebook Guru
    Hi, I have a Razer Blade 15 2070Max-q and I’m trying to use the vbios on the Pro 17 for the 100watt it allows on that 2070Max-q instead of my 90watt. Please if any can help and send me there vbios I would very much appreciate it.
    Thanks
    You can follow these guides to do it.
    https://www.trishtech.com/2017/07/how-to-backup-gpu-bios-or-uefi-from-inside-windows/
    https://www.overclockersclub.com/guides/how_to_flash_rtx_bios/
    Here is the Razer Blade Pro 2070Max-q 100watt vbios
    https://mega.nz/#!o4ZX0IjT!bNy2US-O2P6Ncw5coia32pwqIFjVWo7Wcda9HhJOarY
    Update: 12/8/2019
    Having trouble getting the 100watt tdp with the RBP 2070-Maxq vbios as seen in HWINFO,
    Not only that my core clock speed keeps fluctuating and am not thermal throttling or hitting 90watt tdp limit.
    I know the pic shows 1,680.0 MHz but it gets lower then that while playing and because of that my fps drops to low 50 sometimes for a bit but should't with the hardware I have. My setup in that pic playing COD MW is high settings rtx off on an ultra wide with liquid metal on both gpu and cpu. Any way to get max performance?
    I also took the RBP 2070-Maxq vbios and loaded in Mobile Pascal TDP Tweaker and you can see the Target (mW) is 90000 but the limit Target (mW) is 100000. Could this be the reason why?
    I have the early RB 15 with the 8th gen cpu on motherboard bios v1.05 with tweaks from http://forum.notebookreview.com/thr...trol-of-the-i7-8750h-advanced-version.823065/
    Any help or ideas would very much be appreciated.
    MagillaGorilla likes this.
  2. stranula
    stranula Notebook Consultant
    I can't directly help you, but I can provide some links that you can try if you are interested. I couldn't find any 100W variants, but there are a couple 115W vBIOs available. I think they are all 10DE 1F10, which is the same as RB15 2070, so pretty good chance of working.
    115W - https://www.techpowerup.com/vgabios/212138/212138
    115W - https://www.techpowerup.com/vgabios/211864/211864
    115W - https://www.techpowerup.com/vgabios/211985/211985
    HandsomeGhost likes this.
  3. HandsomeGhost
    Wow awesome, yeah I will definitely give it a try when I get a chance and post back. Thanks @stranula
  4. bjrebo
    bjrebo Notebook Consultant
    i would like to know if this worked and what your results are? Currently, i have a 2070mq with LM and can run 1500 mhz while gaming with no drops.
  5. HandsomeGhost
    Here are my results from using the MSI vbios on Shadow of the Tome Raider
    Im able to go up to 115 power limit but now the voltage it staying beween .625mV to around .700mV which is resulting in lower clock speeds.
    Here is the same area with the stock vbios. I also tried the Asus vbios same results and the display port didn't work unlike on the MSI vbios. Even tried the power throttle mod but no change. If anyone has any input on what can be done please help.
    @bjrebo I also have LM with copper shims and undervolted my gpu. Some games like GTA 5 my clock speed goes up to 1770mhz.
  6. stranula
    Good to see it flashed alright. Not so good to see it isn't giving added performance.
    Some thoughts:
    - Did you completely remove the Nvidia drivers using DDU and reinstall?
    - When you look in HWiNFO, is your GPU Power always at ~115W, even if you aren't using the dGPU?
    - Did you try the modded drivers?
  7. HandsomeGhost
    No I haven't tried any of that. I'll try and report back, Thanks.
  8. stranula
  9. HandsomeGhost
    Okay cool if I don’t notice anything different. I’ll flash that and see. Thanks
  10. HandsomeGhost
    I removed my drivers with DDU and installed the modded drivers. While playing nothing changed voltage still at .650mV and power is at 150.
    I also tried the TongFang vbios same thing.
