Need a laptop model with desktop ryzen or intel cpu and upgradable desktop rtx 3080 gpu in USA
Discussion in 'Sager and Clevo' started by brajesh143, Sep 11, 2021.
  1. brajesh143
    brajesh143 Notebook Geek
    I Need a laptop model with desktop ryzen or intel cpu and upgradable desktop rtx 3080 gpu located in USA
    Kindly help
  2. Tech Junky
    Tech Junky Notebook Deity
  3. Meaker@Sager
    The NP9672 really is your only chassis option.
  4. sydneyblue
    sydneyblue Notebook Guru
    I got mine from HID Evolution plus they are a prema partner so im hoping to get that bios when it release which HID promised i would . I think Origin PC and Gentechpc ( not sure if they are prema partners . is in the usa and there is another im not sure. Eurocom ships from Canada i beleive
  5. Meaker@Sager
    Depends if that's a particular thing you are after.
    sydneyblue likes this.
  6. Tyranus07
    Tyranus07 Notebook Evangelist
    what you are looking for, it doesn't exist. The mobile 3080 isn't remotely close in performance to the desktop 3080. The mobile 3080 is closer to the desktop 3060 Ti. Also forget about the upgradable part, your best bet is a laptop with a MXM port, but that doesn't make it upgradable. Newer MXM cards aren't standard in form factor anymore, so they change in shape from one gen to another.
    4W4K3 likes this.
  7. Meaker@Sager
    We may get a quadro 3089 desktop chip at some point. Will cost more than a car at that point though.
