Need a laptop for a new job
Discussion in 'What Notebook Should I Buy?' started by sarevok9, May 5, 2021.
  1. sarevok9
    sarevok9 Notebook Enthusiast
    1) What is your budget?
    $2500
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" - 16" screen
    3) Which country will you buying this notebook?
    USA
    a. Like: Microsoft, Asus
    b. Dislike: Lenovo, Dell
    No
    Email, testing / compiling code, multivariant testing.
    Both.
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?)
    Minimally, some stuff while traveling should be possible, but I'm thinking games like forager. I have an rtx3090 on my desktop already, so this will not be a gaming machine, nor does it need to be.
    As many as possible.
    Not seeing IRL is okay
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Windows, though I will be running virtualbox with nix containers or a WSL 2 instance.
    Screen Specifics
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    4k, 2k, etc.
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.)
    Doesn't matter
    Build Quality and Design
    Highly
    Notebook Components
    15) How much hard drive space do you need?
    512gb - 1tb nvme
    Timing, Warranty and Longevity
    16) When are you buying this laptop?
    Within a week
    17) How long do you expect to use this laptop?
    4+ years (until I can coax job to do a refresh)
    18) How long could you afford to do without your laptop if it were to fail?
    Irrelevant
    19) Would you be willing to pay significantly extra for on-site warranty, or would it be acceptable to you to have to ship the laptop to the vendor for repair with perhaps a week or more outage?
    No.
    In addition specs that are important to me: CPU, Ram, battery life. The gpu (if present) is not really a selling point to me.
  2. atquantrandash93
    atquantrandash93 Notebook Consultant
    How did you even score a 3090??? And tame the heat??? Respect!
    For your question, the Asus Strix G15, Strix G17, fit your budget, with 5900HX, 3070, base 16GB RAM, 1TB NVMe, and 99Whr battery for $1799 at Bestbuy, but out of stock. A few hundred dollars higher, the Strix SCAR G15, and Strix SCAR G17 may come in variants with the same specs but with QHD screens.
    The downside of these models is that you can only maximize their GPU potential by using a second monitor, as they have Optimus. GizmoSliptech reported a frame rate drop of 10%, I believe.
    Other options include the MSI GE66 Raider, and MSI GE76 Raider. These have MUX switches allowing you to push the GPU, Intel, 3070, 16GB RAM, and 1TB NVMe. With these specs, they are about $500 more than the Strix.
    I suggest 17" variant because the slim bezel design allows the laptop to take up space as much as a 15" one.
    I hope this helps. I think right now, we can only wait for stocks.
    Sent from my LM-V450 using Tapatalk
  3. JRE84
    JRE84 Notebook Virtuoso
    nice advice but hes not looking for a gaming laptop, battery life is of upmost importance according to the response....in that case a ux series asus or zenbook with the 1650
    heres what Id get with your requirements
    https://www.bestbuy.ca/en-ca/produc...-ssd-16gb-ram-gtx1650-max-q-open-box/14931607
    KING19 and Maleko48 like this.
  4. RhyStar
    RhyStar Notebook Consultant
    I am not sure you need to spend so much money.
    I just bought an HP Envy x360 2 in 1 for 1k at Best Buy for my daughter... it is a 1080p but you get better battery life than a 2k or 4K screen... and for your intended use, you should only need 1080p.
    I7 11th gen with 512 and octane.
    Why are you buying a laptop for a job, unless you are consulting? Usually the company buys.
    R
  5. KING19
    KING19 Notebook Deity
    Thats a big budget for your needs.
    But since you're not going to be gaming then i suggest going with a business laptop like the HP Elitebook, Lenovo Thinkpad, Dell Precision and etc. They're built much better than customer based laptops and you'll have better warranty and support also the battery life will be great. You can also go with a Macbook if you want.
    JRE84 likes this.
