NCASE M1 v5 Build
Discussion in 'Desktop Hardware' started by TBoneSan, Jul 16, 2017.
  1. TBoneSan
    TBoneSan Laptop Fiend
    Whoops yeah. I got confused, I was thinking it was Conductonaut.
    I've never found metal on the GPU to be a day and night difference like with CPUs. I haven't done my homework and read the whole article but I would be interested in knowing how they applied it - did they apply it in the HS too. Also with metal it's ever more sensitive to getting the pressure and pads height right. It's hard to scientifically replicate tests or call any of the reviews definitive. However because it is so fickle on the GPU it does make a lot more sense for people to just use conventional pastes and let the thickness take out all the surface pressure guesswork.
    Robbo99999 likes this.
  2. HTWingNut
    HTWingNut Potato
    With laptop CPU's metal paste doesn't do a whole lot. I do like Kryonaut a lot now though. I still use IC Diamond on a system I need to paste and let it go (like friends or family) because it has a solid track record and really doesn't need to ever be replaced that I've found. Kryonaut, I don't know yet, haven't used it for extended periods.
  3. Robbo99999
    Robbo99999 Notebook Prophet
    I think they did apply it to both the heatsink & the GPU. I too applied it to both surfaces, and I'm certain that my heatsink makes very flat contact with my GPU core - it's a really good flat mate (not the kind that leaves all the dirty dishes in the sink - ha!) - so I'm quite certain that my liquid metal vs Kryonaut temperature comparisons are valid - only 1 degC difference between the two.
  4. Robbo99999
    Kryonaut is my favourite paste now, it's given me the lowest temps I've ever seen (apart from liquid metal, but that's only 1 degC less). I've had Kryonaut on my laptop CPU since Jan 2016, and it doesn't need repasting yet, all cores are still within a couple of degrees of each other, etc. I'm done experimenting with liquid metal - I'll keep using it on CPU delids but that's all.
    TBoneSan likes this.
  5. TBoneSan
    Yeah I don't blame you either bro. I don't know why but metal on the GPU has never left a lasting impression on me - I've never lost any sleep going without. Delid on the CPU though.. metal is where it's at.
    I should ask some of the DM3 users with 1080 SLI what they think overall. I used metal on a single 1080, it made no difference but I was using the stock thermal pads.
  6. jaug1337
    jaug1337 de_dust2
    I just want to fair in and say the better the cooler and heatsink, the larger the impact liquid metal provides.
    Greater value is provided once OC'ing comes into the picture, next to some good fujipoly thermal pads.
  7. Tanner@XoticPC
    Tanner@XoticPC Company Representative
    I've been considering a move to Kryonaut personally. With you on ICD, it's pretty much one and done unless you really mess it up.
  8. daysarelost
    daysarelost Newbie
    I love this case. A bit pricey but its elegant and getting custom cables made it a charm. Now i am running full SSD with very minimal cable slack and its quiet AF!
  9. TBoneSan
    Same. I'm still loving it. I'm surprised how silent it is - even under full load.
