NC10 NetBook Brightness FN keys not working
Discussion in 'Samsung' started by notrace, Dec 29, 2008.
  1. notrace
    notrace Newbie
    This is really annoying me! I recently installed a nlited version of xp home, legit copy. I ad it all up and running fine and the brightness worked. and now its stopped working?
    I don't have the num lock on. I have reinstalled graphics drivers. Any help? I really want to be able to increase the birghtness, its awfully dull as it is.
    All other fn keys are working. Yet the brightness keys seem unresponsive and do nothing!
  2. Tinderbox (UK)
    Tinderbox (UK) Sir Pumpkin Longshanks
    Hi.
    I have a Q210 and not a NC10 so i dont know if the following applies.
    Are you using the Samsung display driver or one from somewhere else.
    As the Samsung Driver as screen brightness functions built in , if you use any other driver they do not work.
    Regards
    John.
  3. notrace
    notrace Newbie
    I am using the intel graphics driver which i downloaded from the samsung website.
    Thanks for the input tho!
  4. Tinderbox (UK)
    Hi.
    On my Q210 there is an option in the Bios to adjust the display brightness for Auto to User control.
    Have you upgraded the Bios or Adjusted it.
    Regards
    John.
  5. John Ratsey
  6. notrace
    notrace Newbie
    Thanks for the input guys, really appreciated, i downloaded the display manager and it seems to be working, thanks. weird it was working before but oh well :D
    Thank you :D
  7. jansin62
    jansin62 Newbie
    I also downloaded both the display manager and keyboard magic. It WORKED!!
    Thanks a million.
