NBR Vista Tips and Tweaks Guide
Discussion in 'Microsoft Windows XP and Vista' started by Les, Sep 7, 2007.
  1. Les
    Les Not associated with NotebookReview in any way
    You can reinstall and do it again if it ever slows down. I have tried this to make sure it would work ok again and it does.
    And You cut 49 seconds off your boot??? Sweet!!!!
    I should add a poll to determine what people are cutting their time by on average (lol). This may be the best tweak i have ever found...through Trebuin of course.
  2. jabbok
    jabbok Notebook Deity
    I did the tweaks on my notebook and now it boots in about 45 sec, thanks to all who contributed I will rep each of you
  3. calot
    calot Notebook Evangelist
    SSD drive anyone??
  4. Valkyrie
    Valkyrie Notebook Consultant
    I use O&O Defrag for my Vista system regularly. If I use the TuneXP, will there be a conflict?
    I'm testing the TuneXP on an XP Pro system which also has O&O defrag installed. I'll see how it works, but I wonder if anyone else has tried using both TuneXP and O&O Defrag at the same time on Vista.
  5. Les
    My drive is the SSD drive which defrags just as any other.
    Also I dont think there would be any conflicts between the two... A defrag is a defrag. The TuneXP program id simply reordering your boot files to the front of the disk and then cleaning up the space with the defrag command.
    This post is flying!!!! Love It.
  6. Agent CoolBlue
    Agent CoolBlue Notebook Deity NBR Reviewer
    Flamenko, is there a reason why you always ask for positive rep? It is against the rules.
    Nice thread nonetheless, I would rep you if I could.
  7. Valkyrie
    The thing is, the O&O method I use also reorder the files during defragmenting. So I wonder if it reorders the bootfiles within the C:/$Boot folder. According to O&O, my boot folder (C:/$Boot) is already at the front.
  8. Les
    Cant answer that and yes Lawlz...appreciate the rep as I enjoy helping here...no more no less.
    For the most part though, I wanna see the comments so the article can stay up top for awhile so everyone benefits.
  9. kanehi
    kanehi Notebook Deity
    Program doesn't work with Vista x64. Keeps saying it can't find this and that to open. Oh well.
  10. thisisricardo
    thisisricardo Notebook Guru
    im using vista x64 and it worked perfectly
