NBR Vista Tips and Tweaks Guide
Discussion in 'Microsoft Windows XP and Vista' started by Les, Sep 7, 2007.
  1. ZT3000!
    ZT3000! Notebook Evangelist
    Awesome, def got an improvement in start up time.
    +rep.
  2. tango3065
    tango3065 Notebook Consultant
    Can this program be unistalled after you run it or is this something you have to run often like a regular defragmenter?
  3. Nalada
    Nalada Notebook Evangelist
    Is this a case where you have to click "Show processes from all users" in Taskmanager before they are visible? That would be the case if they are running as "System".
  4. darthsat
    darthsat Notebook Deity
    Yea, I am curious to see why I dont see the 2 processes running.
  5. tango3065
    mine is running as we speak and the 2 processes are called -
    Defrag.exe
    DfrgNtfs.exe
    Hope that helps, also I am still curious if this is just a one time deal or will you have to defragment often?
  6. Sequoia225
    Sequoia225 Notebook Deity
    "2. If you are comfortable with computers...turn UAC off as it is probably the worst thing in Vista. Press Start, click on your picture...turn UAC off and restart.
    Possible important point about "
    Regarding this tweak, I just read this somewhere else.....
    "Do not disable UAC to start with because aside from security issues, if you choose to enable it again in the future, due to file and registry virtualization your settings for any currently installed programs may be lost. "
    Any comments on what this means, (ramifications?)
    thanks.
  7. darthsat
    Once I checked "Show processes from all users" in task manager, I can now see the 2 processes. I'm in the process of defragging now.
    Edit : Finished defragging. So all in all, these 2 tweaks lowered my power-on to fully loaded vista from 1min 7seconds down to 55seconds. Not bad.
  8. mair
    mair Notebook Consultant
    works great thanks
    rrp point
  9. Les
    Les Not associated with NotebookReview in any way
    The program can be uninstalled at any time as it is not resident and has no ties to your system.
    Further, regarding UAC, I have never heard of that before. I have turned UAC on and off several times for several different systems. I would believe if that were true it would be a huge flaw in Vista they would have tackled a long time ago.
    In any case, I have never had troubles turning UAC back on but I cant state that that would never occur. If it has to others i would appreciate someone comment on that specifically.
    PS Its nice to see so many having so much success with this.
  10. tango3065
    Wow and repped, I went from 1 minute 30 secs to now 41 secs.
    BTW I did unistall the program, could you tell me if the boot menu will eventually get fragmented again or is this just a one time deal?
