Narrow USB on CF-29
Discussion in 'Panasonic' started by Slowburnballoon, Feb 1, 2012.
  1. Slowburnballoon
    Slowburnballoon Notebook Enthusiast
    Hey guys,
    On my CF-29ETKGZKM with one USB port, the opening as many of you probably know is pretty narrow and an inch or so deep into the case. I've already run into a couple of my cables and thumb drives that are too wide to fit all the way into the port.
    Is there something you guys are doing to get around this? I did some searching for an adapter of sorts, but didn't come up with much. I did find a nice adapter that flips 90 degrees both directions, but I can't tell online if it is narrow enough or not.
    Any ideas appreciated, thanks!
  2. ADOR
    ADOR Evil Mad Scientist
  3. ADOR
    (double, dang lagging DSL)
  4. Slowburnballoon
    Thanks, for 2 bucks I think it's worth giving a try!
  5. interestingfellow
    interestingfellow Notebook Deity
    radiocrack also use to have an "extender" that many people used.
    I prefer to use a USB extension cable. You my purchase one from Big Lots, Wallyworld, dollar store, and many other major retailers. Of course, often times you get what you pay for. The dollar store ones usually last 2 or 3 months before errors start happening.
    FWIW, YMMV.
  6. ADOR
  7. TopCop1988
    TopCop1988 Toughbook Aficionado
    Panasonic Toughbook CF-29 Mk2
    Model Number: CF-29ETKGZKM
    Status: DISCONTINUED
    MSRP: $4,488
    Description: Intel® Pentium M 718 1.3GHz LV (Centrino) Processor, 13.3" XGA Transmissive Touch Screen, 256MB RAM, 40GB HDD, Intel® 802.11b+g WLAN, Microsoft® Windows® XP Professional
    RadioShack USB Port Plug Extender
  8. Shawn
    Here are 2 solutions.
    usb
    usb2
  9. toughasnails
    Thats the one that most of us bought last year. It just fits in, most of the cheaper ones you will have to trim some of the plastic off.
  10. Alecgold
    Alecgold Notebook Evangelist
    I have a very short USB extender cable, it's just 4 inches long including the male & female usb, so I can pack it without noticing it ever, but it's there when I need it. It was a bit expensive (€9,99) but it works very well and has a thick, strong cable.
