Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    Thanks for testing, it was my is install being mucked up by Microsoft, Clean installed same build as you DJ and it's working again just have to complete my settings for Gaming and then remake the Hyper-V DevOps image and I will be modding drivers again.
    It so nice to now have a nice working system without broken chassis, as well as a 120hz screen to boot.
    Sent from my SNE-LX1 using Tapatalk
    djlenoir likes this.
  2. hacktrix2006
    Right DevOps rebuilt and New Mod package is in testing. #BetaTestersDM
  3. djlenoir
    djlenoir Notebook Guru
    Oops, posted to wrong place. DM sent.
    hacktrix2006 likes this.
  4. hacktrix2006
    Made By:hacktrix2006
    Status: Final Release
    Repack: No
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview will not be held liable for any damage caused if this is installed on your system or other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic if your having issues please post in the thread!
    Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
    Although the Hyper-V Image used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
    Updated Drivers
    Installer: Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.9013.1
    Nahimic 1.4.2.0 UWP
    Nahimic SWC 1.8.4.0
    Realtek Audio Console UWP 1.16.228.0
    Installer:
    SHA-1:8585F9391C8E568BB28261801C8CFE83D7CC7F3E
    Size: 76609515 bytes (73 MiB)
    Virus Total: Result
    For Windows 10 Build: 1803/1809/1903/1909/20H1
    Change Log:
    Code:
    Updated Realtek Audio Driver from 6.0.1.9003.1 to 6.0.1.9013.1
    Update Realtek Audio Console from 1.15.227.0 to 1.16.228.0
    Updated Uninstall Logic
    Supported Systems with this driver pack:
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP70 (Leopard) (Pro)
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT62 Dominator (Pro)
    GT63 Titan
    GT72 Dominator (G) (Pro) (VR)
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI)
    GV Series
    GV62
    GV63
    GV72
    ***Don't panic if the new Laptops/Systems are not in the list they will be supported if their 8th gen counterparts are in the list 9th gen systems will work with this driver.***
    Install instructions:
    - Disconnect from the internet.
    - Reboot System and Enter BIOS/UEFI.
    - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
    - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
    - Now run the Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe Installer
    - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
    - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
    - Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
    - Now let the system boot up fully and re-enable the internet connection.
    ***[IMPORTANT]****
    Known possible bugs and fixes:
    Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
    Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
    then run Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
    Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.4.2.0 UWP effects are not working or its reporting the device is not upto date.
    Solution: Simply run Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run
    Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Jack Detection not working.
    Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
    Issue: Microphone not working after using Nahimic Optimizer.
    Solution: Click Reset inside Nahimic Settings section will fix this.
    Issue: Microsoft Overwritten the installed modded driver.
    Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot
    the system. Then run Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Nahimic 3 reports its device is not compatible basically not working.
    Solution: Run Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Sound has become muffled/suppressed/distorted.
    Issue: I don't want the Nahimic 3 Bloatware!
    Solution: Run Realtek_UAD_6.0.1.9013.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    I would like to thank the following people for whom have helped. I like to personally thank the following users.
    Special Thanks to:
    MoKiChU (Supplying the drivers, however i will be the only support line for these drivers on here)
    New Installer Testers:
    djlenoir
    zboq
    DimitriosMSI
    Original Thanks:
    J95
    epguy3
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    comradeskeleton (Reddit)
    eiraku
    @asm1 Please update the OP with new links when you have time.
    OgUrecheK likes this.
  5. epguy3
    epguy3 Notebook Consultant
    v1.4.14.0 of the Nahimic 3 app recently released to the MS store
  6. hacktrix2006
    However doesn't work on 4th/5th/6th/7th gen systems from MSI which is why it hasn't been included.
  7. epguy3
    I guess v1.4.14.0 has the same problems as with the v1.4.4 & greater releases
    I'm not sure if the Sound Tracker and Microphone options have been brought back with 1.4.14.0
    looks like the 1.4.2.0 version is still the "good" version that not only supports 4th/5th/6th/7th gen Intel systems but also keeps the Sound Tracker and Microphone options available
  8. hacktrix2006
    They changed something after 1.4.2.0 so that when you load the app only the settings cog shows up and the Audio profiles all the other settings for microphone etc do not show I have looked at all the Nahimic files in the appxbundle between 1.4.2.0 and the new versions and the .DLL files seem to have the same other then a few more added ID's. So for 4/5/6/7th gen systems 1.4.2.0 is the last UWP they can use till another version comes out that allows them systems access to new versions. However 8/9/10th gen systems using this installer can still update to the latest Nahimic UWP without issues.
  9. epguy3
    seems like the new version of the Nahimic 3 app adds support for newly released 11th gen intel based MSI systems
    and the "sound tracker engine" button is added on the Settings section of the app in the 1.4.14.0 release where it could either be enabled or disabled - see attached pic
  10. djlenoir
    Someone with an 8th gen (or above) MSI laptop that is able to upgrade their Nahimic 3 app through the store successfully without losing functionality, will you please export your Nahimic registry key and send that to me?
    To export the registry key:
    1. Open the run dialog by clicking on the Start button and select Run (or Windows Key + R)
    2. Type regedit in the Open: edit box and click OK, the following Registry Editor window is opened:
    Navigate to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Nahimic and once you have located the registry key, right click over the folder and select Export, as shown below:
    3. Name the file Nahimic.reg and save it to your desktop.
    4. Zip up the exported Nahimic.reg file and DM me please. I will provide my email address.
    I am comparing the differences in the registry between a working (1.4.2), non-working (1.4.14), and working (1.4.14) install of Nahimic. I have the working (1.4.2) and non-working (1.4.14), but need an export from someone with a 8th gen or higher CPU to see a working (1.4.14).
Similar Threads - Nahimic unsupported systems
  1. Crustieraxe01
    406
