Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    Made By:hacktrix2006
    Status: Final Release
    Repack: No
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview will not be held liable for any damage caused if this is installed on your system or other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic if your having issues please post in the thread!
    Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
    Although the Hyper-V Image used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
    Updated Drivers
    Installer: Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.9003.1
    Nahimic 1.4.2.0 UWP
    Nahimic SWC 1.8.4.0
    Realtek Audio Console UWP 1.15.227.0
    Installer:
    SHA-1: 0AD6B096EF5D64BDA9E00B119EAD2B3B0FB2A096
    Size: 76378018 bytes (72 MiB)
    Virus Total: Result
    For Windows 10 Build: 1803/1809/1903/1909/20H1
    Change Log:
    Code:
    Updated Nahimic SWC from 1.8.3.0 to Nahimic SWC 1.8.4.0
    Updated Realtek Audio Console from 1.14.226.0 to 1.15.227.0
    Updated Realtel Audio Driver from 6.0.1.8996.1 to 6.0.1.9003.1
    Supported Systems with this driver pack:
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP70 (Leopard) (Pro)
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT62 Dominator (Pro)
    GT63 Titan
    GT72 Dominator (G) (Pro) (VR)
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI)
    GV Series
    GV62
    GV63
    GV72
    ***Don't panic if the new Laptops/Systems are not in the list they will be supported if their 8th gen counterparts are in the list 9th gen systems will work with this driver.***
    Install instructions:
    - Disconnect from the internet.
    - Reboot System and Enter BIOS/UEFI.
    - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
    - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
    - Now run the Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe Installer
    - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
    - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
    - Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
    - Now let the system boot up fully and re-enable the internet connection.
    ***[IMPORTANT]****
    Known possible bugs and fixes:
    Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
    Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
    then run Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
    Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.4.2.0 UWP effects are not working or its reporting the device is not upto date.
    Solution: Simply run Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run
    Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Jack Detection not working.
    Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
    Issue: Microphone not working after using Nahimic Optimizer.
    Solution: Click Reset inside Nahimic Settings section will fix this.
    Issue: Microsoft Overwritten the installed modded driver.
    Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot
    the system. Then run Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Nahimic 3 reports its device is not compatible basically not working.
    Solution: Run Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Sound has become muffled/suppressed/distorted.
    Issue: I don't want the Nahimic 3 Bloatware!
    Solution: Run Realtek_UAD_6.0.1.9003.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    I would like to thank the following people for whom have helped. I like to personally thank the following users.
    Special Thanks to:
    MoKiChU (Supplying the drivers, however i will be the only support line for these drivers on here)
    New Installer Testers:
    djlenoir
    zboq
    DimitriosMSI
    Original Thanks:
    J95
    epguy3
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    comradeskeleton (Reddit)
    eiraku
    @asm1 Please update the OP with new links when you have time.
  2. hacktrix2006
    As a side note this will be the very last driver for a while, as i will be rebuilding the complete laptop i am using to fix the broken hinge issues, upgrading the screen and doing my normal Backup Format and Reinstall of Windows and applications including the Dev VM. I will have access to another system my Trusty R61e however i will only be able to reply to questions i will not be able to mod drivers etc on it (Its a dual core after all and there is only so much a Intel T9500 can do). I thank you members for your understanding and i will update you all after i have completed everything.
  3. hacktrix2006
    Can people with 4th 5th 6th 7th gen systems test 9003.1 driver and report back to me if you having issues with Nahimic 3 1.4.2 EQ's not working trying to find a bug.
    Thank you.
    Sent from my SNE-LX1 using Tapatalk
  4. zboq
    zboq Newbie
    Hi, tested on ge62 6qf 6th gen intel i7 and if by EQ You mean voice/bass/treble, then it is working fine in my system :)
  5. hacktrix2006
    Strange as it's not working on mine even did a clean install of Windows to test. Will look more into it next week after laptop rebuild. Are you on the latest Window 10 2H1 build?
  6. zboq
    zboq Newbie
    I've installed latest available build today actually :) and after that I've noticed that it updated my Realtek drivers and Nahimic stopped working.
    Then, downloaded latest build of Your mod and istalled and tested EQ.
    I system is Windows 10 Pro 64-bit (10.0, Build 19041) (19041.vb_release.191206-1406)
  7. epguy3
    epguy3 Notebook Consultant
    i don't know how or why Mokichu does it but he recently updated his unofficial Realtek UAD + NH3 drivers to v6.0.9013.1 several hours ago - see his recent post in the Nahimic forum.
  8. OgUrecheK
    OgUrecheK Notebook Guru
    These are official drivers, but with the installer cut out.
    hacktrix2006 likes this.
  9. hacktrix2006
    Mokichu has been doing this for a bit, as OgurecheUK has said it's basically offical drivers with the realtek setup files removed and instead some script doing the installing.
    However Mokichu's drivers are stock based and thus only work on 8th to 19th gen systems.
    It's why I started to use the drivers from there as it made it far easier and quicker for me to modify them and integrate them.
    However I can't mod the new ones till I have done my OS wipe on my now rebuilt laptop which I will be starting shortly after backing some important data.
    Edit: OS Reinstall, Data placement is done. Just need to recreate the Hyper-V DevOp image and i should be able to mod drivers again.
  10. djlenoir
    djlenoir Notebook Guru
    I verified that voices, treble, bass settings all work in Nahimic app with your 6.0.1.9003.1 driver pack installed. Running Windows 10 Version 2004 (OS Buid 19041.508) currently. I have been always enabling airplane mode on the laptop, performing a Full Uninstall, followed by a Full Install.
Similar Threads - Nahimic unsupported systems
  1. Crustieraxe01
    406
