Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    @epguy3 Updated to Nahimic 3 UWP 1.4.6 and it does the same as 1.4.4 on systems that are lower then 8th gen.
    Sent from my SNE-LX1 using Tapatalk
  2. djlenoir
    djlenoir Notebook Guru
    I found the download link from the log, but I was not able to access it directly.
    Downloading from http://tlu.dl.delivery.mp.microsoft...Zfk4tKKu5//Uu7gORpiVrZq11vThonrruBZ/OduETBA==
  3. hacktrix2006
    Made By:hacktrix2006
    Status: Open Beta
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview will not be held liable for any damage caused if this is installed on your system or other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic if your having issues please post in the thread!
    Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
    Although the Hyper-V Image used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
    Updated Drivers
    Installer: Realtek_UAD_6.0.1.8960.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.8960.1
    Nahimic 1.4.2.0 UWP
    Nahimic SWC 1.8.1.0
    Realtek Audio Console UWP 1.12.219.0
    Installer:
    SHA-1: 16A449A23942211C4630AD75D86300A5370265EC
    Size: 75685207 bytes (72 MiB)
    Virus Total: Result
    For Windows 10 Build: 1803/1809/1903/1909/20H1
    Change Log:
    Code:
    Updated Realtek Driver from 6.0.1.8959.1 to 6.0.1.8960.1
    Updated Nahimic SWC Driver From 1.7.2.0 to 1.8.10
    Supported Systems with this driver pack:
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP70 (Leopard) (Pro)
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT62 Dominator (Pro)
    GT63 Titan
    GT72 Dominator (G) (Pro)
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI)
    GV Series
    GV62
    GV63
    GV72
    ***Don't panic if the new Laptops/Systems are not in the list they will be supported if their 8th gen counterparts are in the list 9th gen systems will work with this driver.***
    Install instructions:
    - Disconnect from the internet.
    - Reboot System and Enter BIOS/UEFI.
    - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
    - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
    - Now run the Realtek_UAD_6.0.1.8960.1_MSI_Nahimic_UWP_mod.exe Installer
    - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
    - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
    - Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
    - Now let the system boot up fully and re-enable the internet connection.
    ***[IMPORTANT]****
    Known possible bugs and fixes:
    Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
    Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
    then run Realtek_UAD_6.0.1.8960.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
    Issue: Jack Detection not working.
    Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
    Issue: Microphone not working after using Nahimic Optimizer.
    Solution: Click Reset inside Nahimic Settings section will fix this.
    Issue: Microsoft Overwritten the installed modded driver.
    Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot
    the system. Then run Realtek_UAD_6.0.1.8960.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.8960.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Nahimic 3 reports its device is not compatible basically not working.
    Solution: Run Realtek_UAD_6.0.1.8960.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.8960.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Sound has become muffled/suppressed/distorted.
    Issue: I don't want the Nahimic 3 Bloatware!
    Solution: Run Realtek_UAD_6.0.1.8960.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    I would like to thank the following people for whom have helped. I like to personally thank the following users.
    New Installer Testers:
    djlenoir
    zboq
    DimitriosMSI
    Original Thanks:
    J95
    epguy3
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    comradeskeleton (Reddit)
    eiraku
    @asm1Please update the OP with new links when you have time.
    PSA: If you have a 6th or 7th Gen System please do not upgrade your Nahimic 3 Application though Windows 10 Store, it will bug out. However if you running a 8th/9th/10th Gen System you can update your Nahimic 3 Application through the Windows 10 Store!.
    OgUrecheK and djlenoir like this.
  4. asm1
    asm1 Notebook Evangelist
    Updated
    djlenoir and hacktrix2006 like this.
  5. hacktrix2006
    Thank you, how are you? Hopefully safe and sound.
  6. hacktrix2006
    I take it with the lack of reports back from users saying if there are issue means everything is working as expected and the new installer can now be classed as Final Release ?
  7. imanuky
    imanuky Newbie
    Great work! Perfect in my MSI GS73VR 7RF STEALTH PRO.
    hacktrix2006 likes this.
  8. djlenoir
    Yeah, sorry, I should have reported back. Everything works exactly as it was intended to on my laptop. Everything tested and validated. In other words, you made it, so of course it works! ;)
  9. hacktrix2006
    Well I guess the original installer can now be safely killed off and removed.
  10. JeanLegi
    JeanLegi Notebook Evangelist
    installed succesful on the GS63VR 6RF and very nice work made!!! awesome what you do since my last beta i was testing. :hi:
