Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. djlenoir
    djlenoir Notebook Enthusiast
    The Nahimic 1.4.4 app is locked down to specific subsystem IDs as it is an exclusive feature for newer MSI laptops. The application makes a check against a .DLL file to validate you are one of the supported systems at launch, and there is not currently a known workaround. The new Nahimic adds support for the mirror driver. The behavior you described indicates you are not one of the supported models, so you can downgrade using @hacktrix2006 installer to the 1.4.2 version. Make sure you disable auto updates in the Microsoft store or it will auto-magically upgrade you again to 1.4.4 and you will have to repeat the process to downgrade.
    hacktrix2006 likes this.
  2. hacktrix2006
    @epguy3 There is will add the files to the next driver release, there is no real point in repacking the installer. It will simply confuse everyone.
    As for the Nahimic 3 V1.4.4 issue i get the same thing too but its to do with an ID check within the latest version of Nahimic's UWP which then uses a .dll file to check on with the Subvendor ID's that are allowed to use it, this is due to an Exclusivity deal it would seem with MSI.
    However i am working on a new installer script that is being actively tested right now.
    Edit: Side note, out of that pack the only thing that is new is just the Extension files, Mirror and SWC drivers are the same in the new installer right now.
  3. hacktrix2006
    Made By:hacktrix2006
    Status: Open Beta
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview will not be held liable for any damage caused if this is installed on your system or other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic if your having issues please post in the thread!
    Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
    Although the Hyper-V Image used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
    Updated Drivers and Realtek Audio Console UWP With NEW INSTALLER!
    Installer: Realtek_UAD_6.0.1.8959.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.8959.1
    Nahimic 1.4.2.0 UWP
    Nahimic SWC 1.7.2.0
    Realtek Audio Console UWP 1.12.219.0
    Installer:
    SHA-1: F17E42C501F1E91C4C601FAE693987B7E686DE4A
    Size: 75446466 bytes (71 MiB)
    Virus Total: Result
    For Windows 10 Build: 1803/1809/1903/1909/20H1
    Change Log:
    Code:
    Updated Realtek Audio Console from 1.11.217.0 to 1.12.219.0
    Update Realtek Driver from 6.0.1.8945.1 to 6.0.1.8959.1
    Now using the new Installer (Looks the same but is not) with its new scripts (Realtek Bloat Removed!), Strunk the installer size from 80MB to 71MB, with recovery records!!
    Drivers are now locked down to MSI (1462) Systems.
    Supported Systems with this driver pack:
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP70 (Leopard) (Pro)
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT62 Dominator (Pro)
    GT63 Titan
    GT72 Dominator (G) (Pro)
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI)
    GV Series
    GV62
    GV63
    GV72
    ***Don't panic if the new Laptops/Systems are not in the list they will be supported if their 8th gen counterparts are in the list 9th gen systems will work with this driver.***
    Install instructions:
    - Disconnect from the internet.
    - Reboot System and Enter BIOS/UEFI.
    - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
    - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
    - Now run the Realtek_UAD_6.0.1.8959.1_MSI_Nahimic_UWP_mod.exe Installer
    - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
    - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
    - Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
    - Now let the system boot up fully and re-enable the internet connection.
    ***[IMPORTANT]****
    Known possible bugs and fixes:
    Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
    Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
    then run Realtek_UAD_6.0.1.8959.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
    Issue: Jack Detection not working.
    Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
    Issue: Microphone not working after using Nahimic Optimizer.
    Solution: Click Reset inside Nahimic Settings section will fix this.
    Issue: Microsoft Overwritten the installed modded driver.
    Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot
    the system. Then run Realtek_UAD_6.0.1.8959.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.8945.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Nahimic 3 reports its device is not compatible basically not working.
    Solution: Run Realtek_UAD_6.0.1.8959.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.8945.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Sound has become muffled/suppressed/distorted.
    Issue: I don't want the Nahimic 3 Bloatware!
    Solution: Run Realtek_UAD_6.0.1.8959.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    I would like to thank the following people for whom have helped. I like to personally thank the following users.
    New Installer Testers:
    djlenoir
    zboq
    DimitriosMSI
    Original Thanks:
    J95
    epguy3
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    comradeskeleton (Reddit)
    eiraku
    @asm1Please update the OP with new links when you have time.
  4. TikiThorsen
    TikiThorsen Newbie
    For what is worth, I "tested" your beta installer (8959.1) after upgrading Win10 to 2004 and it works just as good as it did on 1909.
  5. hacktrix2006
    Glad to hear that.
    Sent from my SNE-LX1 using Tapatalk
  6. OgUrecheK
    OgUrecheK Notebook Enthusiast
    A-Volute Nh3 Audio Effects Component v1.8.1
    Download
    Yes.
    hacktrix2006 and djlenoir like this.
  7. djlenoir
    Interestingly enough, I received this driver update through Windows update today. Is that where you got it as well?
  8. hacktrix2006
    I already have the file, just waiting on my compile for router firmware to finish so I can run some tests before getting sorted for the new installer.
  9. epguy3
    epguy3 Notebook Consultant
    Nahimic 3 uwp app recently updated to v1.4.6 from ms store
    check if 1.4.6 behaves the same as 1.4.4 or if it's better
  10. epguy3
    it may have been available thru WU but not yet listed from MS update catalog as MUC still has the 1.7.2 version and not the newer 1.8.1 version (ms may post it there later this month)
    the WU link may get recorded onto a local windows update log file or event viewer file
    try using "powershell get-windowsupdatelog" command in powershell cmd prompt & view the log file in notepad to get the actual link from MS
Similar Threads - Nahimic unsupported systems
  1. Crustieraxe01
    261
