Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. Alup
    Alup Newbie
    I meant speaker, not studio. This is a built in mic. There was no Optimize Nahimic option for me. I recently updated to this version of windows.
    Edit: Yes, I did the audio troubleshooter many times. I did the full install for the driver each time as well.
  2. hacktrix2006
    Ok here is something for you to test
    Run mmsys.cpl
    Head to the recording area
    Select the Microphone and press properties
    Now head to the listen tab
    Insert a Headphone in to the headphone jack (this will save your ears for feedback)
    Click the Listen checkbox and make sure headphones (Digital Out) is selected.
    Press Apply and click your fingers up close and then work outwards.
    If you get sound from the mic then, let me know what software your running.
    As for the other two @OneOnline @Jageruao3 i think i might know whats causing your issue with volume which might be to do with the microphone so also do the above by running mmsys.cpl in the runbox then heading to the communications tab and select do nothing and then apply see if that helps.
  3. Alup
    Alup Newbie
    I had actually just rolled it back to the 1777 or whatever the version was called, (Well, I reinstalled it completely with the tool for that version) and that works fine for audacity. Perhaps the 1888.1 (Not sure the exact version there either) has compatibility
    issues, so I'll hold off on it for now.
  4. OneOnline
    OneOnline Notebook Enthusiast
    I always turn this feature off, so that is not the problem. I have not tried to install the previous version, I don’t know if it’s worth it. For now, I'm just restarting Nahimic and this temporarily helps.
  5. OgUrecheK
    OgUrecheK Notebook Consultant
    Released a new driver 6.0.8787.1.
    To install you need to follow these steps:
    0. Disable Internet
    1. Run script to uninstall applications Remove-UAD-Appx.ps1
    2. Remove old driver
    3. Install new driver: 8787.1_UAD_WHQL_Nahimic_2019_0830_131455_fix_MSI.zip
    4. Rebooting the PC
    5. Install application Realtek Audio Control UWP
    6. Install application Nahimic 3 UWP
    Nahimic works perfectly.
    Dragon Center does not switch sound profiles. Waiting for fixes from MSI.
  6. hacktrix2006
    Ok you do know then drivers are not modified right so it will only work on 8th gen and 9th gen systems, drivers I supply are modified to work on all MSI laptops.
    Sent from my SNE-LX1 using Tapatalk
  7. OgUrecheK
    I see. But I need an official driver with an unmodified signature.
  8. hacktrix2006
    You can't have a modded driver without breaking the signature. Have you used any of my modded drivers in the past? I see you are new to the forum I even checked your driver hence I know it's not been edited.
    If you look at the title you'll notice it's for unsupported systems aka modified drivers, which is why I include all files with a few click installer which does everything for you. All that's required is SecureBoot to be disabled before running the installer.
    I already had this new build that was released built and I am testing it before uploading it to the normal places.
    What model of laptop do you have?
  9. kill4l
    kill4l Notebook Consultant
    Guys, any ideas from where i can download updated unmodified driver for GE73VR 8RF?
  10. hacktrix2006
    The drivers that @OgUrecheK has linked to are unmodified and should work on your system.
    Although I am just test my version ATM before releasing.
    kill4l likes this.
Similar Threads - Nahimic unsupported systems
  1. iTzZent
    7
    396
