Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    Strange very strange as I am not having this issue myself, which is why multi-system modding blind is hard.
    Nothing showing event logs?
    Sent from my SNE-LX1 using Tapatalk
  2. OneOnline
    OneOnline Notebook Enthusiast
    Where to look?
  3. hacktrix2006
    Event viewer
  4. OneOnline
    No errors except that I have 2 identical Realtek with their identical records.
  5. hacktrix2006
    Ok, this seems very strange. Nothing like this is showing in my Event Viewer, so in the run box could you please type in SystemPropertiesHardware once there click the Device Installation settings, mine looks like
    If your says YES, select NO and reboot the system then re-run the Full install as this would mean that Event ID 2001 means Microsoft just overrode the driver if you look it says IsDriverOEM and Upgrade Device both with true.
  6. OneOnline
    Yes, it was already disabled, I read the instructions :)
  7. hacktrix2006
    Just checking, so its down to i don't know why its happening then. The only suggestion i can think of is to downgrade back to 8777.1 for now.
  8. Jageruao3
    Jageruao3 Notebook Enthusiast
    I just installed 8777 want to try it out... But dont test it yet... But i did everything first time like in instruction, i did the same this time
    Sent from my SM-G965U using Tapatalk
  9. Alup
    Alup Newbie
    I realized with the 8777 version, when I wanted to test something, my mic won't work. Updated to the most recent 878.1, no dice.
    MSI GE62VR 6RF, windows version 1903, in the recording devices tab, the mic pics up, and is set so other programs can use it, tried both with exclusive mode on and off. No apps work with it, nor anything online. How do I fix it?
    (Both studio and mic drivers say device not migrated, if that helps. Installed it multiple times. Sound and Nahimic works. Tried the fixes above.)
  10. hacktrix2006
