Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    Which version did you install? Also it Nahimic 3 app that makes it allow. Hopefully your using it on an MSI branded system else if not I can help you.
    Sent from my SNE-LX1 using Tapatalk
  2. Jageruao3
    Jageruao3 Notebook Enthusiast
    I installed 6.0.1.8781.1, yes i use msi gt73, on windows 10 1809 (17763.6678), i just reinstall everything completely ant its again working, but why... Its seems like nahimic volume stabilizer stop working
    Sent from my SM-G965U using Tapatalk
  3. hacktrix2006
    Could be Microsoft updating the driver to Thier POS version follow the issues section for the fix to that.
  4. Jageruao3
    I did that and i turn off the afterburner too, just too check, because that was the last thin what i install... And seems for my that this version if driver eats some FPS... Do you have like cloud storage? I want to try some older drivers?
  5. hacktrix2006
    Yes I do have it all on mega.nz however there is private beta folders in there too. If you go back a few pages you will be able to test 8777.1 out.
  6. OneOnline
    OneOnline Notebook Enthusiast
    The same thing is with me. I did not check the sound when I turned on the computer a second time after installation. The sound changes in Nahimic, but there are no changes in other applications.
  7. hacktrix2006
    Is the driver version showing the same in device manager? I.e 8781.1?
  8. OneOnline
    Yes, driver 6.0.8781.1.
    Just uninstalled Nahimic, installed it from the Microsoft Store and rebooted the PC. So far, sound works in both Nahimic and games. If the sound breaks again, I'll let you know.
    Another reboot ...
    I understood what the problem is. If you do not start Nahimic after turning on the PC, its effects will not work anywhere. If you start it and then start the game, everything will work.
    What the hell? Nahimic services not starting with the system?
    No, the service is running. Then I do not know what else could be. A temporary solution may be to add Nahimic to the auto start.
  9. Jageruao3
    And i find out one more thin, that some times when sound go down, after reboot it works again, but when you open and close some apps like game, seems like when you close it that the time when sound go down
  10. OneOnline
    Yes, I have the same thing. I closed the game and something in Nahimic broke. The next launch of the game is already without sound improvements.
    Opening Nahimic before launching the game, as expected, solves the problem.
    I saw a feature of background apps from the Windows Store somewhere ... trying to find where.
    In the settings, Privacy, and there is the Background Applications tab. But Nahimic is enabled....
