Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    hacktrix2006 Notebook Deity
    Check the 3 files and look for 1180 in the. Your I'd should be the second one after
    Just checked and it's in there correctly.
    Sent from my LLD-L31 using Tapatalk
  2. Falkentyne
    Falkentyne Notebook Prophet
    I'm confused.
    My ID is "11B1"
    But your INF says 1180.
    There is a "11b1" above it. But again I am confused. I know nothing about this stuff.
  3. hacktrix2006
    On my phone right now however there should be a 1180 then another one under that which is 1158 then your 11B1.
    But will have another go later unless I uploaded wrong file. Will do you later bud.
  4. Falkentyne
    There are "two" 11B1's in the file you sent me (in the first INF file mentioned in the text file. I did not check the next two. It's making me dizzy) :/
    One is in the place you mentioned (1180, 1158, 11B1)
    Another is somewhere else below that. Is it supposed to be like that?
    There's only one 1180..
  5. hacktrix2006
    If there is two 899's with device end 11B1 that might be the issue mate but will check when I get back.
  6. Falkentyne
    I checked the files.
    the first "INF" has two 11B1's which are identical lines. Only one 1180.
    the second INF only has one 11B1.
    The third INF has two 11B1's (identical lines).
  7. hacktrix2006
    The two files with the identical lines in theme edit and remove one of the lines and try again. I really need to place modded id's at the bottom to make life easier. See if that works else redownload the drivers and try without the modded inf to see if that works you might be lucky.
  8. Falkentyne
    Without the INF doesn't work, whether or not I am in test mode (tried both).
    And i know nothing about mods myself. I have no experience in it.. I'm sorry :(
    I'll try removing one but I don't think that will work. i don't feel optimistic. I Feel like there's something else wrong.
    Has your mod worked for others? I mean, why are there 2 lines to begin with?
    that would mean logically that the 11B1 line was already there.
    Perhaps something else needs to be changed?
  9. hacktrix2006
    I think the 11b1 was already there as only two new lines was added by me before hand which was 1180 and 1158.
  10. Falkentyne
    I already went back to the other driver. I need more confirmation that this can work for me however. @asm1 ? I really don't like playing driver hopskotch :(
    Has anyone here successfully done an inf mod like this?
