Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    @DimiGold
    The version in the latest driver is Versoin 1.3.2.0 so it looks like the issue your having is down to microsoft installing the drivers over the top of the modded ones, There is in the same thread as the driver an attached .zip called Windows Auto Driver Updates, download that and inside is two reg files the one you need to use is Disable Auto Driver Updates.reg, merge that reg file to your registery and use the uninstaller again and try again. Your getting closer.
    There is a chance to join the next beta run as well just PM me when the Next beta testers call is made.
  2. Tyler Reding
    Tyler Reding Newbie
    i uninstalled everything to my knowledge (i need some kind of program to wipe all audio drivers from my system to be sure)
    I have disabled windows updating my drivers
    I disabled Driver enforcement
    I used the installation you have and had it restart my system to disable the driver enforcement
    i have done this 10 times...
    i need help
    EDIT: im trying https://github.com/lostindark/DriverStoreExplorer/releases out to delete the drivers
  3. hacktrix2006
    DM me, both of you will need to remote in I think.
    Sent from my LLD-L31 using Tapatalk
  4. Tyler Reding
    Tyler Reding Newbie
    i cant send a dm yet (my permissions havent been updated they update every 24 hrs) plus i have to have 5 messages sent i guess which i think this is the 4th one
  5. Tyler Reding
    Tyler Reding Newbie
    i did just reset my pc again cause i was having issues so it would be eaasaier for you to remote help that way
  6. Tyler Reding
    Tyler Reding Newbie
    nvm i dont need to pm you resetting it finnaly did the trick
    hacktrix2006 likes this.
  7. hacktrix2006
    Thanks for letting me know, normally on major builds I clean install my OS. But glad it's working for you.
  8. felix3650
    felix3650 Notebook Evangelist
    @hacktrix2006 Hey man! I've been out busy with a new work project...I can easily beta test future versions as I'm less busy for the time being ;)
    Will need to install a fresh new Win10 ltsc march '19 updated though as my current Win10 1903 home is too messed up from my own tinkering with GPO and other stuff lol.
    PS: I have the GT73VR with a skylake 6870HK and CM236 chipset (Sabre 9xxx series DAC).
  9. hacktrix2006
    @felix3650 I see you like getting yourself into a mess lol. The next driver update will require another batching of testing.
    felix3650 likes this.
  10. DimiGold
    DimiGold Newbie
    Thx mate it's working now! Thanks for your work a lot! ;)
    Kevin@GenTechPC and hacktrix2006 like this.
