Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. nk950357
    nk950357 Notebook Enthusiast
    Is there any way not to roll back to old version of windows,or if this will be fixed in future?
  2. nk950357
    My nahimic 2+ works with the driver with nahimic 3 moded driver in this thread
    JeanLegi likes this.
  3. hacktrix2006
    You should be able to uninstall updates quick Google search will help you there, if Microsoft knows about the issue there will likely be a fix coming but when is anyone's guess. On another note 1903 doesn't seem to have this issue.
    Sent from my LLD-L31 using Tapatalk
  4. nk950357
    Okay,i’ll try to update to 1903 to see if the problem exists or not.thanks for a really big help!
  5. hacktrix2006
    Backup your system with mcrem reflect before doing so.
  6. JeanLegi
    JeanLegi Notebook Evangelist
    well yesterday i was not able to remove the updates today it is possible. i try it now before doing the clean install.
    hacktrix2006 likes this.
  7. JeanLegi
    nothing changed. clean install in progress.... thank you MS for wasting more time on your BS :bigrolleyes:
  8. hacktrix2006
    :(:mad::(
  9. JeanLegi
    Ladies and Gentlemans,
    nahimic 3 is back in action after clean Installation. And the new Design in 1903 is nice.
  10. hacktrix2006
    Nice one bud.
Similar Threads - Nahimic unsupported systems
  1. Crustieraxe01
    408
