Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. asm1
    asm1 Notebook Evangelist
    Updated, will install tomorrow :)
    hacktrix2006 likes this.
  2. nk950357
    nk950357 Notebook Enthusiast
    Hi,my computer is msi gv62vr 7rf with windows 10 1809 enterprise version.
    after uninstall then install the modded version of nahimic, nahimic won't show unsupport version but "nahimic could not be launched" instead.
    How can I solve with this? Thanks for your wonderful work and help.
    also,Realtek Audo Console won't show msi logo at upper lept corner
    this is my hardware id.Thanks!
  3. hacktrix2006
    First think to check did you have to click Install Driver with a red and white box? if so how many times, also will need a screen shot of your device manager where the Software Componets section is.
    See the main part of the Realtek Audio driver is not modded anymore only two files are which are
    AVoluteNH3Ext.inf
    HDX_MsiExt_AVO_RTK.inf
    So driver signature enforcment needs to be off when you go to install the drivers. Best way is to redownload the driver and uninstaller, Run the uninstaller first whilst disconnected from the internet then when it reboots to advance boot menu Troubleshoot” -> Advanced options -> Startup Settings -> select “Disable driver signature enforcement” option.
    Then install the modded driver whilst internet is still disconnected and reboot once more. It should work
    Also make sure you use the reg file to disable Windows Driver updates which is attached to the post before going back on the internet Micrsoft has a habbit of changing the driver about.
  4. nk950357
    Yes,two times.
    AVoluteNH3Ext.inf
    do you mean this?i couldn't find these two files.
    After redo all steps that you provide,stills get me the same error
  5. hacktrix2006
    Does Uninstall the app and downloading it from Windows Store work? See the driver i give out is the same driver i am using which is working fine.
    The software componets is showing like mine, however i have noticed your using Bluetooth Audio. Have you tried with Bluetooth disabled?
  6. nk950357
    Just try with both solution, but seems doesn’t works.[​IMG]
  7. hacktrix2006
    Did your Windows OS get an update? if so might be worth checking if that broke it. Thats the only thing i control as Microsoft keeps killings stuff with updates.
  8. nk950357
    [​IMG]Recently get these updates.
    I have noticed installed attempt,does it causes this problem?
  9. hacktrix2006
    The latest one might cause an issue someone whom beta tests for me @JeanLegi is also having issues as well. Its not a driver issue its more like a MS issue.
    Try installing an older build just incase go back two builds might help.
  10. JeanLegi
    JeanLegi Notebook Evangelist
    don't think so i testet even Nahimic 2+ with the recommend driver from the MSI support homepage and this doesn't work too.
    i try an cleaninstall to see if everything will working and will report back in maybe 60min or so. i must do a quick backup of some important data.
