Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    No the effects apply automatically you only need to open the app to configure everything.
    Sent from my LLD-L31 using Tapatalk
    LeftEyeNine likes this.
  2. Kevin
    Kevin Egregious
    I've never seen Nahimic 3. Is there anything different or special about it, compared to previous versions?
  3. hacktrix2006
    Nahimic 3 has a decent UI now, Works well with most games unlike Nahimic 2 which would crash games and memory leaks. Been using Nahimic 3 for awhile so Nahimic 2(+) is now a faded memory.
    Sent from my SHIELD Tablet K1 using Tapatalk
  4. asm1
    asm1 Notebook Evangelist
    A bad memory at that :D
    hacktrix2006 likes this.
  5. Spartan@HIDevolution
    It's crappy and it's a matter of luck if it works or not. and no we can't get rid of the Microcrap store since we need to install it from there
  6. Falkentyne
    Falkentyne Notebook Prophet
    Ok @asm1
    I'm dumb and I really need your help :(
    I think looking at trying to get a Zotac GTX 1080 to fit in a GT73VR 1070 heatsink (the GPU core isn't the problem, the VRM heatsink is the problem!) is scrambling my brain.
    I don't know how to successfully install it on a GT73VR Throttlebook.
    I can't even get the realtek "only" drivers installed (without even installing Nahimic 3.0).
    It says some sort of installation error (because of ....u know..DRM).
  7. asm1
    out of my expertise I am afraid ..... :(
  8. Falkentyne
    I know u have to mod the INF for the realtek drivers. But do I use the mod you uploaded? Or do I extract the inf from the "nahimic 2" drivers and copy (whatever file it is for the GT73VR) over? I'm new to that and im VERY dizzy right now. Very dizzy.
  9. asm1
    @hacktrix2006 might be able to shed some light....
  10. hacktrix2006
    Thanks for that, Falk will need screenshot of you Audio ID from device manager so I can upload a modded inf.
