Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. WildCard65
    WildCard65 Notebook Enthusiast
    Since I can't find how to PM you, I'll have to do this way:
    Laptop is GP72 6QF with audio device
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1462115B
    Other UWP Applications include:
    Killer Control Center
    Intel Graphics Command Center
    Other things to note:
    I did refresh the PC with a Windows 10 install from ISO to USB
  2. hacktrix2006
    @WildCard65 how are you disabling Driver Signature Enforcement? as using command prompt version no longer works. Are you sure you have disabled secureboot from the bios before turning off DSE as if secure boot is enable when you turn off DSE it will not turn off DSE as its a SecureBoot protected area. 899 is in the driver.
    The UWP there is not known to cause issues so are ok.
  3. WildCard65
    Ok, found the issue, the instructions regarding DSE were a little unclear:
    It needs to be disabled BEFORE the installer goes to install.
    Clarity required in instructions:
    If the installer uninstalls any pre-existing drivers first, it'll ask for restart, click "No"
    Restart via Shift+Click in Start Menu restart option, proceed to disable DSE
    Windows must ask if you want to install the drivers anyway (red scary box popup), if this doesn't happen, DSE was not disabled.
    Edit: And a quick double re-run of NH3ProductSettings.exe (obtained from V8496) and now I can use NH3.
  4. hacktrix2006
    Ok i have edited the change log and info with the following, *PLEASE DO THIS BEFORE INSTALLING THE MODDED DRIVER*
    Hope fully this makes it more clear.
    @JeanLegi Guess whats happening tonight.
  5. hacktrix2006
    Can't believe you blinked, Oh yes another Update!!
    Realtek_UAD_6.0.1.8678_MSI_Nahimic_UWP_mod (ONLINE!)
    Made By:hacktrix2006
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview will not be held liable for any damage caused if this is installed on other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic if your havving issues please post in the thread!
    Package includes:
    Realtek UAD 6.0.1.8678
    Nahimic 1.2.13.0 UWP
    Realtek Audio Console 1.2.175.0 UWP
    UAD *299* MSI supported models
    Nahimic 3 280+
    SHA1: C1E7F0B537DDD85B01052337A7FC3B7FEF15C135
    For Windows 10 Build: 1803/1809/1903
    Change Log:
    Code:
    Updated Driver from 8673 to 8678.
    Code:
    GT76_Titan_8SE                          GE73VR_7RE                              GL72MVR_7RFX                             GP72MVR_7RFX                           GS73VR_6RF                              GV62VR_7RF
    GT76_Titan_8SF                          GE73VR_7RF                              GL72M_7RDX                               GP72MVR_7RGX                           GS73VR_6RG                              GV62_7RC
    GT76_Titan_8SG                          GE73_7RC                                GL72M_7REX                               GP72M_7RDX                             GS73VR_7RF                              GV62_7RD
    G25VR_7RE                               GE73_7RD                                GL72VR_7RFX                              GP72M_7REX                             GS73VR_7RG                              GV62_7RE
    GE62MVR_6RF                             GE73_Raider_8SF                         GL72_6QE                                 GP72VR_6RF                             GS73_6RE                                GV62_8RC
    GE62MVR_6RG                             GE73_Raider_8SG                         GL72_6QF                                 GP72VR_7RFX                            GS73_7RE                                GV62_8RD
    GE62MVR_7RG                             GE73_Raider_RGB_8RE                     GL72_6RD                                 GP72_6QD                               GS73_Stealth_8R                         GV62_8RE
    GE62VR_6RF                              GE73_Raider_RGB_8RF                     GL72_6RE                                 GP72_6QE                               GS73_Stealth_8R                         GV72VR_7RF
    GE62VR_7RF                              GE75_Raider_8RE                         GL72_7QF                                 GP72_6QF                               GS73_Stealth_8R                         GV72_8RC
    GE62_6QC                                GE75_Raider_8RF                         GL72_7RDX                                GP72_6RD                               GS73_Stealth_8R                         GV72_8RD
    GE62_6QD                                GE75_Raider_8SE                         GL72_7RD                                 GP72_6RE                               GT62_6RD                                GV72_8RE
    GE62_6QE                                GE75_Raider_8SF                         GL72_7REX                                GP72_7QF                               GT62_6RE                                P65_Creator_8RD
    GE62_6QL                                GE75_Raider_8SG                         GL72_7RE                                 GP72_7RDX                              GT63_Titan_8RE                          P65_Creator_8RE
    GE62_6RD                                GF62VR_7RFX                             GL72_8RE                                 GP72_7RD                               GT63_Titan_8RF                          P65_Creator_8RF
    GE62_6RE                                GF62_7RD                                GL73_7RD                                 GP72_7REX                              GT63_Titan_8RG                          PE60M_6RD
    GE62_7RD                                GF62_7RE                                GL73_7RE                                 GP72_7RE                               GT65_Titan_8SE                          PE60M_6RE
    GE62_7RE                                GF62_8RC                                GL73_8RC                                 GP73_7RD                               GT65_Titan_8SF                          PE60M_7RD
    GE63VR_7RE                              GF62_8RD                                GL73_8RD                                 GP73_7RE                               GT65_Titan_8SG                          PE60M_7RE
    GE63VR_7RF                              GF62_8RE                                GL73_8RE                                 GP73_Leopard_8RC                       GT72VR_6RD                              PE60_6QD
    GE63_7RC                                GF63_8RB                                GP62MVR_6RF                              GP73_Leopard_8RD                       GT72VR_6RE                              PE60_6QE
    GE63_7RD                                GF63_8RC                                GP62MVR_7RFX                             GP73_Leopard_8RE                       GT72VR_7RD                              PE60_6RD
    GE63_Raider_8SF                         GF63_8RD                                GP62MVR_7RF                              GP73_Leopard_8RF                       GT72VR_7RE                              PE60_6RE
    GE63_Raider_8SG                         GF72VR_7RFX                             GP62MVR_7RGX                             GP73_Leopard_8SF                       GT72_6RD                                PE60_7RD
    GE63_Raider_RGB_8RE                     GF72_7RD                                GP62M_6RD                                GS43VR_6RE                             GT73VR_6RE                              PE60_7RE
    GE63_Raider_RGB_8RF                     GF72_7RE                                GP62M_6RE                                GS43VR_7RE                             GT73VR_6RF                              PE62VR_7RF
    GE72MVR_6RG                             GF72_8RC                                GP62M_7RDX                               GS63VR_6RF                             GT73VR_7RE                              PE62_7RD
    GE72MVR_7RG                             GF72_8RD                                GP62M_7RD                                GS63VR_6RG                             GT73VR_7RF                              PE62_7RE
    GE72VR_6RF                              GF72_8RE                                GP62VR_6RF                               GS63VR_7RF                             GT75VR_7RE                              PE62_8RC
    GE72VR_7RF                              GF73_8RC                                GP62VR_7RFX                              GS63VR_7RG                             GT75_Titan_8RF                          PE62_8RD
    GE72_6QC                                GF73_8RD                                GP62VR_7RF                               GS63_6RE                               GT75_Titan_8RG                          PE70_6QD
    GE72_6QD                                GL62M_6RD                               GP62_6QD                                 GS63_7RE                               GT83VR_6RE                              PE70_6QE
    GE72_6QE                                GL62M_6RE                               GP62_6QE                                 GS63_Stealth_8RC                       GT83VR_6RF                              PE70_6RD
    GE72_6QL                                GL62M_7RC                               GP62_6QF                                 GS63_Stealth_8RD                       GT83VR_7RE                              PE70_6RE
    GE72_6RD                                GL62M_7RDX                              GP62_6QG                                 GS63_Stealth_8RE                       GT83VR_7RF                              PE70_7RD
    GE72_6RE                                GL62M_7RD                               GP62_6RD                                 GS63_Stealth_8RF                       GT83_Titan_8RF                          PE70_7RE
    GE72_7RD                                GL62M_7REX                              GP62_6RE                                 GS65_Stealth_Thin_8RE                  GT83_Titan_8RG                          PE72_7RD
    GE72_7RE                                GL62M_7RE                               GP62_7QF                                 GS65_Stealth_Thin_8RF                                                          PE72_7RE
    GL62_6QE                                GL62VR_7RFX                             GP62_7RDX                                GS65_Stealth_Thin_8SE                                                          PE72_8RC
    GL62_6QF                                GP62_7RD                                GP63_7RE                                 GS65_Stealth_Thin_8SF                                                          PE72_8RD
    GL62_6RD                                GP62_7REX                               GP63_Leopard_8RC                         GS65_Stealth_Thin_8SG                                                          PL60_6RD
    GL62_6RE                                GP62_7RE                                GP63_Leopard_8RD        PL60_6RE
    GL62_7QF                                GP62_8RC                                GP63_Leopard_8RE        PL60_7RD
    GL62_7RDX                               GP62_8RD                                GP63_Leopard_8RF        PL60_7RE
                                            GP63_7RD                                GP63_Leopard_8SF        PL62_7RC
                                            GL62_7RD        PL62_7RD
                                            GL62_7REX        PL62_7RE
                                            GL62_7RE        PS42_8M
                                            GL62_8RE        PS42_8RB
                                            GL63_7RD        PS42_Modern_8RC
                                            GL63_7RE        PS63_Modern_8M
                                            GL63_8RC        PS63_Modern_8RC
                                            GL63_8RD        PS63_Modern_8RD[/CENTER]
    - Uninstall Realtek UAD, including Nahimic UWP, Realtek Audio Console apps then reboot.
    - BIOS -> disable secure boot (Important for Unsigned Drivers as it blocks the next step). *PLEASE DO THIS BEFORE INSTALLING THE MODDED DRIVER*
    - Disable driver signature enforcement. Hold down the Shift key while you click the “Restart” option -> Select “Troubleshoot” -> Advanced options -> Startup Settings -> select “Disable driver signature enforcement” option. *PLEASE DO THIS BEFORE INSTALLING THE MODDED DRIVER*
    - Temporarily disable AV software.
    - Copy to desktop then Right-click/Run as administrator "Realtek_UAD...mod.exe".
    - When prompted (2x/3x) select "Install driver software anyway"
    - Realtek installer, select "No, I will restart my computer later" to continue with RTK Audio Console & Nahimic installation (Invisible install)
    - Check Start Menu to ensure Realtek Audio Control UWP and Nahimic 3 has been installed.
    - Finally, reboot.
    ***[IMPORTANT]****
    Known possible bugs and fixes:
    Jack Detection not working, simply go to Realtek Audio Console Disable and Re-enable it.
    Microphone no longer working after Nahimic Optimises, click Reset inside Nahimic will fix this.
    ***[IMPORTANT]****
    ***[IMPORTANT]******USE Windows Auto Driver Update.zip On systems with Intel 6th Gen or higher CPU (Thank microsoft for forcing drivers on to you)**
    ** Else its not needed, Download for driver is right at the top***[IMPORTANT]****
    I would like to thank the following people for whom have helped
    The Master for his teachings and pointing me down the right path: J95
    The Beta Testers, Without them issues wouldn't be found:JeanLegi, mnomaanw, epguy3
    Community whom has trusted my work: LeftEyeNine, Falkentyne, felix3650, asm1, Bazgrim, ixende, MrBeer, arke yyci, Beemo, senso, Eflatun,
    HitZ2976, Ivan994,
    For Posting this in another Languge on other threads: JeanLegi
    For Honest Feedback: epguy3
    Finally and Most importantly, Thank you to Alanfox2000 for making the drivers easy to access.
    @asm1 Time to Update OP
    JeanLegi likes this.
  6. JeanLegi
    JeanLegi Notebook Evangelist
    nothing... will install the new one tomorrow :D.
    I can remeber that someone wrote that he do a little break round abouth 1 month :rolleyes::D
    I was bored so i check the new driver... Party with my beyerdynamic MMX300 (hardstyle for the victory! :D )
    Installed and it is working perfect with my GT75VR 7RF. Good work as everytime bra!
    hacktrix2006 likes this.
  7. hacktrix2006
    Lol, yep I seem to have lost all space and time, however I seem to have lost the joy of gaming and we all know what idle hands do.
    Sent from my LLD-L31 using Tapatalk
  8. hacktrix2006
    Ready for 19H1 Public Release!!
    Realtek_UAD_6.0.1.8683_MSI_Nahimic_UWP_mod (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.8683
    Realtek Audio Console 1.3.177.0 UWP
    Nahimic 3 280+
    SHA1: 091299C41A0B22861622B39977FC1E635BEA4D3C
    Change Log:
    Code:
    Updated Driver from 8678 to 8683
    Updated Realtek Audio Console to 1.3.177.0
    Code:
                                            GL62_7RD        PL62_7RD
                                            GL62_7REX        PL62_7RE
                                            GL62_7RE        PS42_8M
                                            GL62_8RE        PS42_8RB
    - Finally, reboot.
    ***[IMPORTANT]****
    ***[IMPORTANT]****
    HitZ2976, Ivan994,
    linhares, asm1 and JeanLegi like this.
  9. asm1
    asm1 Notebook Evangelist
    updated
    JeanLegi and hacktrix2006 like this.
  10. hacktrix2006
    Thank you
