Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    hacktrix2006 Notebook Evangelist
    Right uninstall everything, Nahimic Realtek sound and app download the Windows reg patch attached on my post. Reboot with DSE off and try again. It sounds like Windows Update did driver downgrade via Windows Update system, the Zip attached on my post stops that happening.
    Then re-installing the package again with Driver Enforcement Off and reboot again.
    Sent from my LLD-L31 using Tapatalk
  2. HitZ2976
    HitZ2976 Newbie
    Same effect
  3. hacktrix2006
    Ok lets check the Device ID, if you could give me your Sound card Device ID which can be found with dxdiag's sound tab under Hardware ID.
    I am not busy tonight so will be able to assist you better.
  4. Ivan994
    Ivan994 Notebook Consultant
    I did steps you write on the first page and everything is working. Am I that lucky? I have MSI gt 73 6rf Nahimic_3.JPG
    JeanLegi and asm1 like this.
  5. asm1
    asm1 Notebook Consultant
    Yes, yes you are :D
    Ivan994 likes this.
  6. TheM4D
    TheM4D Notebook Enthusiast
    Adding/replacing designated device id to AVoluteNH3Ext.inf works with disabling driver signature enforcement. Didn't do anything besides that on my system and everything works properly.
  7. hacktrix2006
    What do you mean any modded driver requires that driver Enforcement is disabled in order for it to work.
    Else all drivers would work without having to do that.
  8. hacktrix2006
    @Ivan994 There is in the thread Links that has pre-mad modded drivers by myself and j95 which are now at 8591 Driver Version, give them a shot as well, but well done on modding your own driver.
    Ivan994 likes this.
  9. Ivan994
    @hacktrix2006 Thank you! Could you share a link with me please?
    I'll be glad to try your drivers!
  10. hacktrix2006
    On post #147
    Ivan994 likes this.
