Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. imanuky
    imanuky Newbie
    No problem. I stick with an old installer that works perfect for me. Thank you for your work!
    hacktrix2006 likes this.
  2. Ricardo_estep
    Ricardo_estep Newbie
    -From "9215.1" to "9250.1", there is a bug over the "PowerShell Script" at "APO3".
    Says something in red, like "error over condition if - AVoluteNH3Ext.inf", and it doesn't work.
    -It clears and unistalls everything good, but only "install the Nahimic App, without any driver".
    I made a little frankestein, with "9210 installer" and i could install the "9250 version" with it. 3456635.png
    --The old installers, work too over "Windows 11" without any problem. If you update to Windows 11, i recomend you to reinstall this driver, cause over installation process, will delete them, as they are "not signed". 6436234.png
  3. epguy3
    epguy3 Notebook Evangelist
    so folks, how's the sound quality with the 6.0.9250.1 MSI drivers on your MSI systems? better or worse than 9238? I ask because of this review of 9250 in ten forums.
  4. hacktrix2006
    You sir are a star, will look into that part of the script, is it possible to have an English output please.
    You might have found the bug that is causing the installer issues. Nice find.
    Sent from my SNE-LX1 using Tapatalk
  5. hacktrix2006
    @Ricardo_estep Your not going to believe what caused the issue a simple { } set was missing.
    Would you be willing to test the correct script please.
    Just override the file in the /Scripts folder bud and run the command like you did before.
    I even checked the APO4 script too and that had the same errors. Sorry everyone for stuffing up with the scripting.
    Ricardo_estep likes this.
  6. hacktrix2006
    Made By:hacktrix2006 and djlenior
    Status: Final Release
    Repack: No
    CodeName: Zeus
    Downgrade/Update: Update
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic (SteelSeries) or MSI if your having issues please post in the thread!
    Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
    Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
    Installer: Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.9250.1
    Nahimic 1.8.9.0 UWP
    Nahimic SWC 3.3.3.0 (APO3)
    Nahimic SWC 4.5.0.0 (APO4)
    Nahimic Extension 1.1.43.0 (APO3)
    Nahimic Extension 1.2.43.0 (APO4)
    Nahimic Mirroring Driver 1.0.4.0
    Realtek Audio Console UWP 1.29.256.0
    Installer:
    SHA-1: 100010130 bytes (95 MiB)
    Virus Total: Result
    For Windows 10 Build: 1909/20H1/20H2/21H1
    Change Log:
    Code:
    Updated Realtek Universal Audio Drivers from 6.0.9238.1 to 6.0.9250.1
    Corrected Install scripts errors. Thanks Ricardo_estep
    Supported Systems with this driver pack:
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP70 (Leopard) (Pro)
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT62 Dominator (Pro)
    GT63 Titan
    GT72 Dominator (G) (Pro) (VR)
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI) (VR)
    GV Series
    GV62
    GV63
    GV72
    ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.***
    Install instructions:
    - Disconnect from the internet. (Not Required, so very Optional)
    - Reboot System and Enter BIOS/UEFI.
    - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
    - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
    - Now run the Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe Installer
    - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
    - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
    - Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
    - Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet)
    ***[IMPORTANT]****
    As i no longer have a MSI Laptop can users please report any and all issues to this forum thread so i can rectify them quickly.
    Known possible bugs and fixes:
    Issue: Two Nahimic Mirroring device show up in Device Manager:
    Solution: run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install.
    Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
    Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
    then run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
    Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.8.9.0 UWP effects are not working or its reporting the device is not upto date.
    Solution: Simply run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
    Issue: Jack Detection not working.
    Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
    Issue: Microphone not working after using Nahimic Optimizer.
    Solution: Click Reset inside Nahimic Settings section will fix this.
    Issue: Microsoft Overwritten the installed modded driver.
    Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot
    the system. Then run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Nahimic 3 reports its device is not compatible basically not working.
    Solution: Run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
    Issue: Sound has become muffled/suppressed/distorted.
    Issue: I don't want the Nahimic 3 Bloatware!
    Solution: Run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    I would like to thank the following people for whom have helped. I like to personally thank the following users.
    Project Programmers:
    hacktrix2006
    djlenoir
    Installer Testers:
    DimitriosMSI
    TikiThorsen
    Ricardo_estep
    Driver Suppiler
    MSI
    Original Thanks:
    epguy3
    J95
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    comradeskeleton (Reddit)
    eiraku
    @asm1 Please update the OP when you have time thank you.
    All good things must come to an end, this will be the very last driver for a while, due to being unable to test the driver on bare metal
    and the fact that my time might soon be very limited as things in my life are changing hopefully for the better!.
    @imanuky @DVB-Yas @bbb18 This should fix your issue, please delete the original c:\audio\9250.1 folder before running the installer.
    bbb18 and Ricardo_estep like this.
  7. Ricardo_estep
    @hacktrix2006 I have tested, and reinstalled, "9250.1" drivers completly without any problems now. Thank you so much :notworthy:.
    @epguy3 I couldn't test "9238.1", but, i normally use "Dolby Atmos" too, with the "Nahimic 3 Processing". At the moment, it doesnt sound bad with "9250.1". I didn't notice too, about, "hard" changes at sound from "9210.1". If your sound becomes "compressed", you should don't forget to enable this. 2325346.png
    --Looks like there is a "new option" too over "Windows 11". I don't know at all what it does... :nah: But it has to be enable from here.
  8. hacktrix2006
    Looking for someone to help out with the driver packs installer if anyone is interested hit me up on PM's.
  9. bbb18
    bbb18 Notebook Enthusiast
    @hacktrix2006 Sorry for the delay reply. I also confirm the new version works as intended!
    I noticed that it took a little while longer to install than the previous versions, and now some Steelseries Devices appears (probably due to the new drivers) but i don't mind too much :)
    Thank you again for all the amazing work!! ;)
  10. hacktrix2006
    Thanks for reporting a success. Its amazing how much damage {} being missing can be.
