Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. OgUrecheK
    OgUrecheK Notebook Consultant
    upd Realtek Audio Driver v6.0.1.9250 APO3 / APO4 (the archive contains outdated APO SWC drivers).
  2. hacktrix2006
    Made By:hacktrix2006 and djlenior
    Status: Final Release
    Repack: No
    CodeName: Zeus
    Downgrade/Update: Update
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic (SteelSeries) or MSI if your having issues please post in the thread!
    Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
    Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
    Installer: Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.9250.1
    Nahimic 1.8.9.0 UWP
    Nahimic SWC 3.3.3.0 (APO3)
    Nahimic SWC 4.5.0.0 (APO4)
    Nahimic Extension 1.1.43.0 (APO3)
    Nahimic Extension 1.2.43.0 (APO4)
    Nahimic Mirroring Driver 1.0.4.0
    Realtek Audio Console UWP 1.29.256.0
    Installer:
    SHA-1: 100010130 bytes (95 MiB)
    Virus Total: Result
    For Windows 10 Build: 1909/20H1/20H2/21H1
    Change Log:
    Code:
    Updated Realtek Universal Audio Drivers from 6.0.9238.1 to 6.0.9250.1
    Supported Systems with this driver pack:
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP70 (Leopard) (Pro)
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT62 Dominator (Pro)
    GT63 Titan
    GT72 Dominator (G) (Pro) (VR)
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI) (VR)
    GV Series
    GV62
    GV63
    GV72
    ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.***
    Install instructions:
    - Disconnect from the internet. (Not Required, so very Optional)
    - Reboot System and Enter BIOS/UEFI.
    - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
    - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
    - Now run the Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe Installer
    - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
    - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
    - Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
    - Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet)
    ***[IMPORTANT]****
    As i no longer have a MSI Laptop can users please report any and all issues to this forum thread so i can rectify them quickly.
    Known possible bugs and fixes:
    Issue: Two Nahimic Mirroring device show up in Device Manager:
    Solution: run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install.
    Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
    Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
    then run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
    Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.8.9.0 UWP effects are not working or its reporting the device is not upto date.
    Solution: Simply run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
    Issue: Jack Detection not working.
    Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
    Issue: Microphone not working after using Nahimic Optimizer.
    Solution: Click Reset inside Nahimic Settings section will fix this.
    Issue: Microsoft Overwritten the installed modded driver.
    Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot
    the system. Then run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Nahimic 3 reports its device is not compatible basically not working.
    Solution: Run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
    Issue: Sound has become muffled/suppressed/distorted.
    Issue: I don't want the Nahimic 3 Bloatware!
    Solution: Run Realtek_UAD_6.0.1.9250.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    I would like to thank the following people for whom have helped. I like to personally thank the following users.
    Project Programmers:
    hacktrix2006
    djlenoir
    Installer Testers:
    DimitriosMSI
    TikiThorsen
    Driver Suppiler
    MSI
    Original Thanks:
    epguy3
    J95
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    comradeskeleton (Reddit)
    eiraku
    @asm1 Please update the OP when you have time thank you.
    All good things must come to an end, this will be the very last driver for a while, due to being unable to test the driver on bare metal
    and the fact that my time might soon be very limited as things in my life are changing hopefully for the better!.
  3. imanuky
    imanuky Newbie
    Not working on MSI gs73vr 7rf stealth pro.
    I tried:
    1. Completely uninstall.
    2. Install again (apo3 and 4).
    3. Secureboot disabled.
    4. Internet disabled.
    5. Antivirus disabled.
    4 Attempts with complete uninstallation previously performed...
  4. NeXt3R
    NeXt3R Notebook Evangelist
    send device ID for verification or for new release
    dxdiag
    SOUND / HW ID
  5. imanuky
    imanuky Newbie
    Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211AC&REV_1000
  6. hacktrix2006
    OS? Windows 10 or Windows 11
    List of all Device ID's in the pack
    HDXMSI Device ID:
    Code:
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211AC  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621118  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462111B  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621123  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621125  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621134  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621138  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621139  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621148  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621149  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462114A  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_14621143  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_14621155  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_14621158  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1462115B  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_14621164  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1462116A  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1462116B  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1462116C  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1462116D  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1462116E  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_14621171  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_14621180  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211AD  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211B1  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211C0  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211C7  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211D1  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211D3  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211E1  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211E2  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211E8  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211E9  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211AF  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_14621200  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0900&SUBSYS_1462D811  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462114B  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462114C  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462114D  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462115C  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462115D  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621190  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_14621193  ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462119A ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_14621205 ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211AE ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211D6 ; HDA Converted to UAD
    "Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_1462DA78 ; HDA Converted to UAD
    Your device ID is at the very top.
    Also 7th gen is APO3 only APO4 is for 10th gen and above
    If you PM me i could Teamviewer in and see whats going on.
    But at this rate i will removing APO4 as these issues really seem to be since i changed the installer to include APO4 into the package.
  7. imanuky
    imanuky Newbie
    Windows 10
    [MODERATOR NOTE] Please provide an English translation.
  8. hacktrix2006
    @imanuky Windows 10 should work, this might sound strange run a Display Driver Uninstaller run and select AUDIO do it in safe mode with networking (Just incase you have a Microsoft Account that you log in with) then restart with no network and try running the script again. If it fails after that then hit me up in DM's and i will remote in and have a look to see whats going on.
    As your device ID is in the list of drivers id's so it should be installing without issue.
  9. imanuky
    imanuky Newbie
    II have tried to install as indicated but it has not worked. I will wait for the next version. Thank you.
  10. hacktrix2006
    @imanuky If your sure to wait for next version it might be awhile as my time is very limited now adays.
