Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. bbb18
    bbb18 Notebook Enthusiast
    @hacktrix2006
    The latest 2 versions (9215 and 9238) stopped working for me (Audio Console doesn't open and Nahimic says something about the device not supported).
    I already tried following the instructions (Full Uninstall and Full Install) but to no avail.
    9210 drivers works fine, even after updating the apps to the latest version (Nahimic v1.8.9 & Realtek Audio Console v1.29.256.0).
    I have an MSI GS73VR-7RF on Windows 10 21H1 x64.
    DeviceID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211AC&REV_1000.
    Note: I installed the APO3 version, which i believe it's the correct one in my case.
  2. DVB-Yas
    DVB-Yas Notebook Enthusiast
    They do not work for me either
    The previous version(9210), when I had Windows 10, it worked APO4, but now I have Windows 11 and it works APO3, but APO4 not work.
    Please check and fix it
    I have an Windows 11 21H2
    DeviceID:
    HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_1462DA78&REV_1000
  3. DVB-Yas
    If possible, put Nahimic 3 and Nahimic 4 separately in the installation program (alone)
  4. hacktrix2006
    @bbb18 I have checked the ID and its not in the drivers however please download the attached fix into the c:\audio\9238.1\Win64 folder if asked overwrite the files then head to c:\audio\9238.1 and execute launch.exe this should fix your issue
    @DVB-Yas You don't say what model you have or even CPU if you have a 6th 7th or 8th gen CPU APO 3 is all that will work. But you have also hit the issue with Windows 11 that has been reported before. However checking the ID in the driver list its in the APO3 driver section.
    Can you try the following steps
    Code:
    1) Open CMD as Admin
    2) Type "bcdedit /set testsigning on" (Without the Quotes)
    3) Reboot the system
    4) Now open Powershell as Admin (important)
    5) Cd into c:\Audio\9238.1\scripts folder
    6) Type "PowerShell -NoProfile -NonInteractive -InputFormat None -ExecutionPolicy Bypass ./FullInstallAPO3.ps1" (Again without the quotes)
    7) After this finishes type "bcdedit /set testsigning off" (again without the quotes)
    8) Reboot the system one last time
    As for your image request i am not sure what your asking FULL APO3 Install is everything for APO3 and FULL APO4 Install is for everything APO4, unless your after the APO being split off.
    As for your device ID DVB its in the driver so its something getting blocked somewhere hence the above.
    bbb18 and DVB-Yas like this.
  5. DVB-Yas
    The problem still persists
    I do not have a driver installed at all!
  6. hacktrix2006
    @DVB-Yas You have secure boot disabled in bios? Did you see a Windows Watermark when it rebooted to install the driver?
  7. DVB-Yas
    I did it according to your instructions, but still the driver was not installed
    I installed the
    I restarted
    I added my hardware ID inAPO4\Extension\AVoluteNH3Ext.inf and it was easily installed in test mode
  8. DVB-Yas
    yes
  9. DVB-Yas
    The shape of the menu has changed and it is interesting:
  10. hacktrix2006
    @DVB-Yas did you run the commands like in the quote earlier? or did you execute the APO4 installer script from the /scripts folder ?
    Reason i am asking is to find where this bug is.
    Downside to installing APO4 is if your Laptop model is not in NH3ProductSettings.cab file EQ will not work, you can't even edit that file either to add a speaker config.
Similar Threads - Nahimic unsupported systems
  1. iTzZent
    8
    507
