Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    I have another way of getting APPX and eppx files bud lol don't need that software lol.
    Sent from my LLD-L31 using Tapatalk
  2. Beemo
    Beemo BGA is totally TSK TSK!
    Whenever I install the RHD Audio driver from an internal drive, its gives me an error that the file cannot be installed, but when I install it from an external drive no problem. My laptop is GT75VR running Windows 10 Home. Anyone here having the same problem?
    The driver came from MSI support page for GT75. hacktrix's driver seems to install just fine though.
  3. hacktrix2006
    You might need to right click the zip file and unblock it, the joys of extra steps with Windows 10. Also try J95's driver the master of driver modding released a new version then mine.
    j95 likes this.
  4. senso
    senso Notebook Deity
    J95 mod works fine on the MSI GT72 2QE.
    And thank you once again hacktrix2006 for all your help doing an initial mod for me and then spending some time doing tech support.
    j95 and hacktrix2006 like this.
  5. Beemo
    It would seems that installation is working by disabling driver signature. Strange because this came from MSI GT75VR support page.
    P.S
    GT75VR is not listed @j95 driver.
  6. j95
    j95 Notebook Deity
    Yes it is...downloaded the Clevo version instead?
    Code:
    "Realtek High Definition Audio" = IntcAzAudModel,HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_14621205
    You must disable DSE before installing modded drivers.
    Code:
    - Uninstall Realtek UAD, including Nahimic UWP app then reboot.
    - BIOS -> disable secure boot.
    - Disable driver signature enforcement. Hold down the Shift key while you click the “Restart” option -> Select “Troubleshoot” -> Advanced options -> Startup Settings -> select “Disable driver signature enforcement” option.
    - Temporarily disable AV software.
    - Copy to desktop then Right-click/Run as administrator "Realtek_UAD...mod.exe".
    - When prompted (3x) select "Install driver software anyway"
    - Realtek installer, select "No, I will restart my computer later" to continue with RTK Audio Console & Nahimic installation
    - Close command line window after it's done.
    - Finally, reboot.
  7. Beemo
    GT76 that must be GT75 you mean?
    j95 likes this.
  8. j95
    j95 Notebook Deity
    Your model HWIDs were included HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_14621205
    Listed here.
    GT73VR_6RE
    GT73VR_6RF
    GT73VR_7RE
    GT73VR_7RF
    GT75VR_7RE
    GT75_Titan_8RF
    GT75_Titan_8RG
    GT83VR_6RE
    GT83VR_6RF
    GT83VR_7RE
    GT83VR_7RF
    GT83_Titan_8RF
    GT83_Titan_8RG
    hacktrix2006 and Beemo like this.
  9. hacktrix2006
    @Midas Touch I can confirm that your Device ID is in the drivers that J95 has made there are a lot of Device ID's in J95's drivers.
    Just download the file, Follow J95's instructions and install you'll be grateful you did.
    j95 and Beemo like this.
  10. Beemo
    My Apologies. I did not see that you need to scroll all the way to the right to see that there are more list of devices.
