Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    Well PVE Server is back online and everything else is also back online.
  2. epguy3
    epguy3 Notebook Evangelist
  3. hacktrix2006
    Will get on to it later it's 00:42 in morning and I have only just managed to chill.
    Edit: Enjoy the driver, i am now off to sleep.
    Sent from my SNE-LX1 using Tapatalk
  4. hacktrix2006
    Made By:hacktrix2006 and djlenior
    Status: Final Release
    Repack: NO
    Downgrade/Update: Update
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic or MSI if your having issues please post in the thread!
    Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
    Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
    Installer: Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.9175.1
    Nahimic 1.7.2.0 UWP
    Nahimic SWC 3.3.1.0
    Nahimic Extension 1.1.43.0
    Nahimic Mirroring Driver 1.0.3.0 / 8.51.48.758
    Realtek Audio Console UWP 1.27.252.0
    Installer:
    SHA-1: B99BE0870A0C97DD7F240565AD008B34F808F920
    Size: 92680587 bytes (88 MiB)
    Virus Total: Result
    For Windows 10 Build: 1909/20H1/20H2/21H1
    Change Log:
    Code:
    Upgraded Realtek Audio Drivers from 6.0.1.9132.1 / 6.0.1.9151.1 to 6.0.1.9175.1
    Upgraded Realtek Audio Console from 1.26.251.0 to 1.27.252.0
    Upgraded Nahimic 3 UWP from 1.6.5.0 to 1.7.2.0
    Supported Systems with this driver pack:
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP70 (Leopard) (Pro)
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT62 Dominator (Pro)
    GT63 Titan
    GT72 Dominator (G) (Pro) (VR)
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI) (VR)
    GV Series
    GV62
    GV63
    GV72
    ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.***
    Install instructions:
    - Disconnect from the internet. (Not Required, so very Optional)
    - Reboot System and Enter BIOS/UEFI.
    - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
    - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
    - Now run the Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe Installer
    - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
    - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
    - Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
    - Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet)
    ***[IMPORTANT]****
    As i no longer have a MSI Laptop can users please report any and all issues to this forum thread so i can rectify them quickly.
    Known possible bugs and fixes:
    Issue: Two Nahimic Mirroring device show up in Device Manager:
    Solution: run Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install.
    Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
    Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
    then run Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
    Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.5.7.0 UWP effects are not working or its reporting the device is not upto date.
    Solution: Simply run Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run
    Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Jack Detection not working.
    Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
    Issue: Microphone not working after using Nahimic Optimizer.
    Solution: Click Reset inside Nahimic Settings section will fix this.
    Issue: Microsoft Overwritten the installed modded driver.
    Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot
    the system. Then run Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Nahimic 3 reports its device is not compatible basically not working.
    Solution: Run Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Sound has become muffled/suppressed/distorted.
    Issue: I don't want the Nahimic 3 Bloatware!
    Solution: Run Realtek_UAD_6.0.1.9175.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    I would like to thank the following people for whom have helped. I like to personally thank the following users.
    Project Programmers:
    hacktrix2006
    djlenoir
    Installer Testers:
    DimitriosMSI
    TikiThorsen
    Driver Suppiler
    MSI
    Original Thanks:
    epguy3
    J95
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    comradeskeleton (Reddit)
    eiraku
    @asm1 Please update the OP when you have time thank you.
  5. hacktrix2006
    Any issues with new driver?
  6. bbb18
    bbb18 Notebook Enthusiast
    Hello hacktrix!!
    Been using your new driver and no issues so far on my MSI GS73VR-7RF. Everything working smoothly!
    Thank you again for all your hard work!
    hacktrix2006 likes this.
  7. nk950357
    nk950357 Notebook Enthusiast
    My MSI GV62VR 7RF couldn't install these drivers:
    Have Tried full uninstall/DDU then reinstall but wont works
    Nahimic keep gives me this error
    I found that nahimic devices wouldn't be installed in device manager
    Windows 20H2
    tried for an hour but with no good results :(
  8. NeXt3R
    NeXt3R Notebook Evangelist
    dxdiag ,.,.and send HW ID for audio device
    dolby ?? another extension ?? ,.,..,only realtek + nahimic
    edit
    you must use the mode "unsigned drivers -enabled" advanced windows reboot
    and try manual install all from extracted folder ? "as admin" ,.,.,..or there was a script
    verify drivers vs device manager "stop windows update"
  9. hacktrix2006
    Disable Secureboot in the UEFI BIOS.
    If you did this already then I am going to need your Audio Device ID which can be got from dxdiag. From there I will mod the files and send you the modded files with instructions.
    @NeXt3R the script for the installer does everything to allow unsigned drivers, the only thing the end user must do is disable secureboot before installing. If it doesn't work after that its a missing Device ID issue which can be quickly fixed once i have the Audio Device ID for that device.
  10. NeXt3R
    yes ,.,.or this mode "windows drivers signature - off" + deactivate "STOP" windows update
    ,.,.using script or manual INF
    tested .,,.and works also ;)
    ,.but it probably has a different configuration ,.,.DOLBY ? + some next virtual drivers
    must send ID
Similar Threads - Nahimic unsupported systems
  1. iTzZent
    8
    508
