Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    Made By:hacktrix2006 and djlenior
    Status: Final Release
    Repack: YES
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic or MSI if your having issues please post in the thread!
    Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
    Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
    HOTFIX
    Installer: Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.9088.1
    Nahimic 1.5.7.0 UWP
    Nahimic SWC 3.2.2.0
    Nahimic Extension 1.1.43.0
    Nahimic Mirroring Driver 1.0.3.0 / 8.51.48.758
    Realtek Audio Console UWP 1.24.243.0
    Installer:
    SHA-1: F01B97ABB01B14D5EF91F30067C8208C78D198AB
    Size: 79265816 bytes (75 MiB)
    Virus Total: Result
    For Windows 10 Build: 1903/1909/20H1/20H2
    Change Log:
    Code:
    Applied a HOTFIX for missing Device ID's simular to original 9088.1 Driver Mod!
    Supported Systems with this driver pack:
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP70 (Leopard) (Pro)
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT62 Dominator (Pro)
    GT63 Titan
    GT72 Dominator (G) (Pro) (VR)
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI)
    GV Series
    GV62
    GV63
    GV72
    ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.***
    Install instructions:
    - Disconnect from the internet. (Not Required, so very Optional)
    - Reboot System and Enter BIOS/UEFI.
    - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
    - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
    - Now run the Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe Installer
    - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
    - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
    - Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
    - Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet)
    ***[IMPORTANT]****
    Known possible bugs and fixes:
    Issue: Two Nahimic Mirroring device show up in Device Manager:
    Solution: run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe and select Uninstall first before using Full Install.
    Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
    Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
    then run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe and select Downgrade Nahimic.
    Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.5.7.0 UWP effects are not working or its reporting the device is not upto date.
    Solution: Simply run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe select Uninstall and then after its completed the Uninstall re-run
    Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe and select Full Install.
    Issue: Jack Detection not working.
    Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
    Issue: Microphone not working after using Nahimic Optimizer.
    Solution: Click Reset inside Nahimic Settings section will fix this.
    Issue: Microsoft Overwritten the installed modded driver.
    Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot
    the system. Then run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe and select Full Install.
    Issue: Nahimic 3 reports its device is not compatible basically not working.
    Solution: Run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe and select Full Install.
    Issue: Sound has become muffled/suppressed/distorted.
    Issue: I don't want the Nahimic 3 Bloatware!
    Solution: Run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod-hf.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    I would like to thank the following people for whom have helped. I like to personally thank the following users.
    Project Programmers:
    hacktrix2006
    djlenoir
    Installer Testers:
    DimitriosMSI
    TikiThorsen
    Driver Suppiler
    MSI
    Original Thanks:
    epguy3
    J95
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    comradeskeleton (Reddit)
    eiraku
    @asm1 Please update the OP with new links when you have time.
    @Ricardo_estep This includes the fix i gave you.
  2. epguy3
    epguy3 Notebook Evangelist
  3. OgUrecheK
    OgUrecheK Notebook Consultant
    I think that can use this driver because it seems that the driver structure is the same for UAD MSI RTK and UAD MSI Nahimic.
    UAD MSI Nahimic only the optional APO Nahimic driver is present.
  4. hacktrix2006
    Major Edit: So After being a complete tool and deleting the DevBox VM and its backups.
    I have managed to reinstall the OS, tools, driver files, workflow scripts back to the system.
    Just doing a few tests before i say its completely back online. However as the other VM which was the router firmware compiler was also wiped it means i will still be unable to do any driver mods till i have that VM back online and a complete firmware compile completed.
    The main thing is, i have managed to get 99% back to where it was before the chaos happened on the DevBox, all i lost was the APO4 files which was extracted ready to make another attempt to merge the driver mod to APO4 over APO3.
    zboq likes this.
  5. hacktrix2006
    Well after doing all my tests the DevBox VM is 100%, still finishing my main Firmware Compiler VM (Doing its first compile for caching) but i am now back to where i was. Sorry about that folks.
  6. TikiThorsen
    TikiThorsen Notebook Enthusiast
    For what is worth, the lastest version of the mod that works for me is 9079.1, any newer and Nahimic app does not work, but the Realtek does.
  7. hacktrix2006
    Shove me you Device ID bud, I might of missed it during the clean up on the last 2 drivers. As I decided to make it cleaner and an easier workflow but as always mucked it up.
    Found your Device ID from one of the DM's we had
    Code:
    VEN_10EC&DEV_0892&SUBSYS_1462DA34
    Just checked the files and its missing in the AVoluteNH3Ext.inf file
    So download the Hotfix 9088.1 then close the installer and head to C:\Audio\9088.1HF\Win64\ThirdParty\Extension folder,
    then at the bottom add the following line.
    Code:
    %Device.ExtensionDesc% = DeviceExtension_Install,HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462DA34    ; HDA Converted to UAD
    Save the file and run C:\Audio\9088.1HF\launch.exe
    That will fix the issue.
    I have added the line to my main file which i will then transfer over to the workflow when my firmware compile has finished.
    Sent from my SNE-LX1 using Tapatalk
    TikiThorsen likes this.
  8. TikiThorsen
    I followed your instructions and now it works correctly again, thank you!
    hacktrix2006 likes this.
  9. hacktrix2006
    That ID is now in the workflow so it will not go missing again. Sorry about that.
  10. hacktrix2006
    Repack: NO
    Installer: Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.9102.1
    Nahimic 1.5.7.0 UWP
    Nahimic SWC 3.2.2.0
    Realtek Audio Console UWP 1.24.244.0
    Installer:
    SHA-1: 7EBF50B9603F640C8C31B26213F698BDFB99BF30
    Size: 79354089 bytes (75 MiB)
    Virus Total: Result
    For Windows 10 Build: 1909/20H1/20H2
    Change Log:
    Code:
    Updated Realtek Audio Driver from 6.0.1.9088.1 to 6.0.1.9088.1
    Updated Realtek Audio Console UWP from 1.24.243.0 to 1.24.244.0
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT63 Titan
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI)
    GV Series
    GV62
    GV63
    GV72
    - Now run the Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe Installer
    ***[IMPORTANT]****
    Solution: run Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install.
    then run Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
    Solution: Simply run Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run
    Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    the system. Then run Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Solution: Run Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Solution: Run Realtek_UAD_6.0.1.9102.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    hacktrix2006
    djlenoir
    Installer Testers:
    DimitriosMSI
    TikiThorsen
    Driver Suppiler
    MSI
    Original Thanks:
    epguy3
    J95
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    eiraku
    Ricardo_estep and TikiThorsen like this.
