Made By:hacktrix2006 and djlenior Status: Final Release Repack: No Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems! Due to this being a Modified Driver, support will not be given via Nahimic or MSI if your having issues please post in the thread! Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results, Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included. Updated Drivers and Nahimic 3 UWP Application Installer: Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe (ONLINE!) Package includes: Realtek UAD 6.0.1.9088.1 Nahimic 1.5.7.0 UWP Nahimic SWC 3.2.2.0 Nahimic Extension 1.1.43.0 Nahimic Mirroring Driver 1.0.3.0 / 8.51.48.758 Realtek Audio Console UWP 1.24.243.0 Installer: SHA-1: 91453BA212E06ECB21DBE5B71C5CDFAA0741AB69 Size: 79264127 bytes (75 MiB) Virus Total: Result For Windows 10 Build: 1903/1909/20H1/20H2 Change Log: Code: Updated Realtek Audio Driver from 9084.1 to 9088.1 Updated Nahimic 3 UWP from 1.5.4.0 to 1.5.7.0 Updated Realtek Audio Console from 1.20.238.0 to 1.24.243.0 Supported Systems with this driver pack: Alpha Series Spoiler Alpha 15 Bravo Series Spoiler Bravo 15 Bravo 17 GE Series Spoiler GE60 (Apache) (Pro) GE62 Apache (Pro) GE63 Raider (RGB) GE65 Raider GE66 Raider GE70 (Apache) (Pro) GE72 Apache (Pro) GE73 Raider (RGB) GE75 Raider GF Series Spoiler GF62 GF63 (Thin) GF65 Thin GF72 GF75 Thin GL Series Spoiler GL62 GL63 GL65 (Leopard) GL72 GL73 GL75 (Leopard) GP Series Spoiler GP60 (Leopard) GP62 Leopard (Pro) GP63 Leopard GP65 Leopard GP70 (Leopard) (Pro) GP72 Leopard (Pro) GP73 Leopard GP75 Leopard GS Series Spoiler GS40 Phantom GS43 Phantom Pro GS60 Ghost (Pro) GS63 Stealth (Pro) GS65 Stealth (Thin) GS66 Stealth GS70 Stealth (Pro) GS72 Stealth (Pro) GS73 Stealth (Pro) GS75 Stealth GT Series Spoiler GT60 (Dominator) GT62 Dominator (Pro) GT63 Titan GT72 Dominator (G) (Pro) (VR) GT73 Titan (Pro) GT75 Titan GT76 Titan (DT) GT83 Titan (SLI) GV Series Spoiler GV62 GV63 GV72 ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.*** Install instructions: - Disconnect from the internet. (Not Required, so very Optional) - Reboot System and Enter BIOS/UEFI. - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer! - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!). - Now run the Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe Installer - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3. - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again! - Now head back into your BIOS/UEFI and Re-enable SecureBoot!! - Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet) ***[IMPORTANT]**** Known possible bugs and fixes: Issue: Two Nahimic Mirroring device show up in Device Manager: Solution: run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install. Issue: Nahimic 3 updated via Windows 10 Store and no longer works. Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates, then run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic. Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.5.7.0 UWP effects are not working or its reporting the device is not upto date. Solution: Simply run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: Jack Detection not working. Solution: Simply go to Realtek Audio Console Disable and Re-enable it. Issue: Microphone not working after using Nahimic Optimizer. Solution: Click Reset inside Nahimic Settings section will fix this. Issue: Microsoft Overwritten the installed modded driver. Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot the system. Then run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: Nahimic 3 reports its device is not compatible basically not working. Solution: Run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: Sound has become muffled/suppressed/distorted. Solution: Run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: I don't want the Nahimic 3 Bloatware! Solution: Run Realtek_UAD_6.0.1.9088.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic Issue: I have re-installed the driver due to Nahimic 3 Reporting that the device is not compatible, however this only started since Driver pack 9084.1. Soluion: Check that the Device ID is in the driver in the file called AVoluteNH3Ext.inf located in C:\Audio\9088.1\Win64\ThirdParty\Extension If it is missing please let me know you Device ID and i will tell you what you need to add into that file, before you can run C:\Audio\9088.1\launch.exe again. Reason: It would seem due to the Device ID refactoring in the workflow script i use i missed some Device ID's (Main reason for the refactoring as it was getting messy). However any new Device ID's that are MSI system base will be re-added to the workflow ready for next release. Currently a known one is for the MSI GT72 VR 6RE click HERE for the fix! ***[IMPORTANT]**** I would like to thank the following people for whom have helped. I like to personally thank the following users. Project Programmers: Spoiler hacktrix2006 djlenoir Installer Testers: Spoiler DimitriosMSI TikiThorsen Driver Suppiler Spoiler MSI Original Thanks: Spoiler epguy3 J95 JeanLegi LeftEyeNine Falkentyne mnomaanw felix3650 asm1 Bazgrim ixende MrBeer arke yyci Beemo senso Eflatun HitZ2976 Ivan994 Alanfox2000 OneOnline OgUrecheK comradeskeleton (Reddit) eiraku @asm1 Please update the OP with new links when you have time.
I was afraid that MSI would do something like this - update the Realtek audio Nahimic driver package, taking out the Nahimic APO3 driver and putting in the Nahimic APO4 driver instead which only works with recent MSI laptops & boards (esp. newly released MSI Z590 series boards that use Nahimic APO4 instead of APO3) good thing I saved a copy of the 9084 driver on a usb drive that still had the latest Nahimic APO3 driver before MSI decided to release the 9088 driver several days later
Firstly, Thanks for not showing any faith in my Modded Driver pack. Secondly, The Nahimic APO Driver is version 3.2.2.0 12/08/2020. Thirdly, Yes there is both NahimicAPO3ConfiguratorDaemonModule.dll and NahimicAPO4ConfiguratorDaemonModule.dll as well as a NahimicPnPAPO4ConfiguratorDaemonModule.dll file in the same directory however i can assure you its APO 3. I also tested the driver since you gave it me, yes my Server was compiling router firmware which meant i couldn't make the installer but i was still able to test the driver using a copy of the script i had and edited for such an occasion. Did the driver work on my 6th gen system, Yes does it have a Working EQ yes, is my system MSI well yes. Is your system an MSI system your using this driver on?? I think not. If i remember correctly its not an MSI system. But if you think you can do better, then please take over doing the mods, updating scripts making the installer, doing the changelog's, doing all the tech support. As quite frankly i have more better things to do with my time. Sent from my SNE-LX1 using Tapatalk
MSI quickly realized this and recently posted another v6.0.9088.1 driver package that does include the Nahimic APO3 driver "restore" file instead of the APO4 driver file (found this other 9088 driver package listed for some B450 Gaming Pro series boards) all is good now
Hi all. Thanks a lot for your work , i have been using this driver for years, as i discovered them... But the last ones "9084" / "9088", I have tried to install them several times and "Nahimic 3" keeps not working. My laptop is a "MSI GT72 VR 6RE Tobii", "6Gen + GTX1070". -The message "Nahimic 3 effects are not working or the device is not upto date" shows up and cannot do anything, "Reinstalling" or even pressing "Downgrade option" of those installers. Version "9079" keeps working good, with effects. Using even "Nahimic 3 1.5.7" / "SWC 3.2.2" / "Companion 1.1.4"... I made a little "frankestein" using the "9088 drivers". But "Codec" one cannot install it, without getting out nahimic effects. Can you know why is this happening? Thanks for all of your work and time.
Are you able to give me a Device ID for your sound card bud, 9084.1 and 9088.1 I redid the Device ID's to try and clean my workflow so I might have accidentally left out some ID's without known about it. You can use dxdiag if you wish and link it in a DM. Sent from my SNE-LX1 using Tapatalk
So fast reply... It's this one:: Description: "Altavoces (Realtek(R) Audio)" -Hardware ID: "HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211AF&REV_1000" -Driver Name: "RTKVHD64.sys" -Driver Version: "6.0.9079.1 (English)" -Driver Provider: "Realtek Semiconductor Corp." -HW Accel Level: "Emulation Only" -Cap Flags: "0xF1F" Name: "Controladora de High Definition Audio" -Device ID: "PCI\VEN_10DE&DEV_10F0&SUBSYS_11AF1462&REV_A1\4&11468B0&2&0108" Name: "Controladora de High Definition Audio" -Device ID: "PCI\VEN_8086&DEV_A170&SUBSYS_11AF1462&REV_31\3&11583659&0&FB" This is all i could get from "DxDiag". Thanks for your time.
Right i am having a look to see if that ID is in the drivers will get back to you. Right i have found the file that had the ID missing, so your going to need to manually edit and add a line for now i will have it added for the next release. So in C:\Audio\9088.1\Win64\ThirdParty\Extension open the file AVoluteNH3Ext.inf and the add this line to the rest of the device id's section. Code: %Device.ExtensionDesc% = DeviceExtension_Install,HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_146211AF ; HDA Converted to UAD Save the file, then head to C:\Audio\9088.1\ and run the launch.exe file. This will correct the issue for you. To anyone else whom has an issue with the driver with an MSI system please give me your Device ID from DXDiag and i will check and add it to the workflow script ready for any new releases. I will also give you which files to manually edit and line to add till a new release is released, like i have above.
No problem, will check all the other ID's as well just incase. Feedback from fellow MSI users is always welcome. Any other issues let me know. Sent from my SNE-LX1 using Tapatalk Update: I have missed a few ID's it would seem, so once my router firmware compile is finished i will be adding the Device ID's in and making a Repack installer from the same base files as the currently release.
